Please post here any bug you found or any feature you want to see in SMath Studio.
Moderators:
Administrators
Data Files Handling
ioan92
ioan92
03/05/2013 14:09:10(UTC)
4
1,545
uni
06/05/2013 19:55:33(UTC)
GUI text translations get cut off
kilele
06/05/2013 17:36:36(UTC)
4
816
kilele
06/05/2013 19:43:46(UTC)
Stack function
Not working as in the Beam.sm example
Dham
03/05/2013 21:14:46(UTC)
6
1,533
Dham
04/05/2013 03:16:26(UTC)
strings errors
08/08/2012 21:24:33(UTC)
3
1,169
mkraska
04/05/2013 01:11:32(UTC)
Hard to create the expression a:=b|c
BTS issue SS-55
mkraska
12/01/2013 17:46:35(UTC)
1
673
mkraska
04/05/2013 00:56:47(UTC)
Inconsistent shortcuts with german keyboards
BTS issue SS-35
mkraska
08/06/2012 12:48:35(UTC)
3
1,076
mkraska
04/05/2013 00:19:03(UTC)
wrong mixed second derivateves
omorr
omorr
25/06/2012 11:17:37(UTC)
7
1,863
omorr
03/05/2013 23:32:12(UTC)
Output description of the functions takes a long time
uni
uni
03/05/2013 20:39:59(UTC)
0
382
uni
Adjusting paper size
leopold
17/03/2013 11:11:34(UTC)
4
941
02/05/2013 16:28:43(UTC)
Difference between symbolic and numeric calculation on imaginary unit
Expression (1/i)*(1/i) , symbolic result "1", numeric result "-1"
Gossage
28/11/2012 12:11:37(UTC)
4
1,340
01/05/2013 01:18:04(UTC)
itereate product bug
can't write primitive name from canvas
12/01/2013 15:12:05(UTC)
2
653
01/05/2013 01:17:38(UTC)
Setting tools/options/font size in Win7
Whatever I set in "Settings", the font size always return to "10"
Engineer
23/04/2013 13:30:52(UTC)
1
736
23/04/2013 13:41:12(UTC)
Help with speeding up calculations
Smath runs slow when calculating
sublim21
16/04/2013 18:32:11(UTC)
7
1,235
sublim21
16/04/2013 20:50:27(UTC)
Embedded image problem between Windows and Linux (.NET and Mono)
Embedded image doesn't show in Linux
DuaneKaufman
12/04/2013 16:54:48(UTC)
5
2,138
omorr
12/04/2013 22:01:58(UTC)
Problem in the units conversion [frequence]
The software doesn´t distingue the units [rad/s] and [hz]
HugoGatti
02/04/2013 19:16:56(UTC)
13
4,418
mikekaganski
04/04/2013 12:22:07(UTC)
Guest (6)
New Posts |
No New Posts |
Hot Topic (New Posts) |
Hot Topic |
New Posts (Locked) |
No New Posts (Locked) |
Announcement (New Posts) |
Announcement |
Sticky (New Posts) |
Sticky |
Poll (New Posts) |
Poll |
Moved |
