First of all - HEllo! and thanks for the great work done with this amazing piece of software: I run smath095 with libmono on Xubuntu 12.04. My start-script is:
exec mono "./SMathStudio_Desktop.exe" "$@"
When I trie to change the sheet size from the default value of "A3" to another one with "File - Page Setup" I am able to choose any size of paper, but this does not do anything, because when repeating the command sequence, I am still on "A3"? Any hints? - Thanks in advance! Leopold Edited by moderator 01 May 2013 01:16:12(UTC)
| Reason: Not specified
This is fixed. The same issue was sometimes on Windows machines as well.
I will give the new version a try asap! Thanks in advance for your great and useful work!
Originally Posted by: leopold I will give the new version a try asap! Thanks in advance for your great and useful work! so sorry to tell you it still does not work. Also the printing dialogue crashes the application
Hmm, it must be some another Mono related issue only.
Will check it later. Thank you.
