SMath Studio Forum
Bugs & Problems
Hard to create the expression a:=b|c
Joined: 15/04/2012(UTC) Posts: 1,988 Was thanked: 1126 time(s) in 723 post(s)
Hi, when trying to generate a table of function values for boolean operators I found the input behaviour of OR, AND and XOR quite confusing. typing a:1|0 or a:1&0 I get a:1|0 and a:1|0This is not what I expected. Instead, I have to use braces to make sure the boolean operation is evaluated before the assignment operation: a1|0) and a1|0) by typing a: (1|0 This implies that the assignment operator has higher priority than boolean AND, OR and XOR, which is odd. I guess that the design intent is that AND, OR and XOR take lower priority than numeric comparison operations. This facilitates writing conditionals like 0<x&x<1 by just typing 0<x&x<1 However, precedence over assignment is confusing. What sensible boolean result is the assignment operator supposed to provide? Thus I propose to re-adjust the operator precedence, such that there is no need to bracket the rhs of an assignment. Edit: Additionally, the equal and not-equal operators silently adopt the same lower precedence like the mentioned boolean operators, but do not enforce brackets around their operators. This leads to wrong results. Martin Kraska Edited by user 23 March 2014 17:57:03(UTC)
| Reason: Not specified File Attachment(s): mkraska attached the following image(s): |
Originally Posted by: mkraska Edit: Additionally, the equal and not-equal operators silently adopt the same lower precedence like the mentioned boolean operators, but do not enforce brackets around their operators. This leads to wrong results.
The issues remain open in 0.96, in particular the cited issue is dangerous. mkraska attached the following image(s): |
SMath Studio Forum
Bugs & Problems
