Here it is. losa-forum.sm (863kb) downloaded 10 time(s).Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
Joined: 04/07/2015(UTC) Posts: 6,866  Was thanked: 983 time(s) in 811 post(s)
Originally Posted by: GermanJG  Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined". data not defined probably indicates some plugins not installed. Maybe other problems wrt your version.
Originally Posted by: GermanJG  Here it is. Document does not open ... incorrect format
 SMath Studio Desktop 64-bit Version: 1.0(build: 8348) Date: 9/11/2022 ConditionallyFormattedLabel: 1.0.8138.35454
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,726   Location: Italy Was thanked: 1396 time(s) in 910 post(s)
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error. ![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45963&b=2) The same happens if you try to force a numerical evaluation using eval() ![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45965&b=2) Edited by user 17 January 2023 17:25:39(UTC)
Originally Posted by: Davide Carpi  If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error. ![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45963&b=2) The same happens if you try to force a numerical evaluation using eval() ![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45965&b=2) That is it! As allways thanks!! But still don't understand why Jean files fails.
Originally Posted by: GermanJG  SMath Studio Desktop 64-bit Version: 1.0(build: 8348) Date: 9/11/2022 Slide left the Formatted Label Side right the graph, remove the Σ no definido You should see the plot.
Originally Posted by: GermanJG  That is it!
As allways thanks!! You're welcome! Originally Posted by: GermanJG  But still don't understand why Jean files fails. There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file. If you remove the 3 inline evaluations it will work. ![2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png](/forum/resource.ashx?a=45968&b=2) Edited by user 17 January 2023 18:28:39(UTC)
My file can be an example of things NOT to do. Originally Posted by: Davide Carpi
Hi, Can we manage the units that are displayed? I have a load in kN/m2 and the result appears as kg/(m*s2). The idea is to present only positive values (with the appropriate unit). kind regards Conditionally Formatted Labels_unity.sm (6kb) downloaded 12 time(s).
The easier way might be something like this ![2023-10-14 18_53_23-SMath Solver - [Conditionally Formatted Labels_unity.sm_].png](/forum/resource.ashx?a=48194&b=2) Code:press2text(x):line(concat(var2str(x/'kPa,1),"\0020\kN\002F\m\00B2\"),1,1)
Thank you very much. This is exactly what I needed.
Hi, I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
Originally Posted by: Karol_R  I'm looking for a way to represent the letter D as a subscript You can subscribe whatever. mysystem dot HelloGrandMa
Originally Posted by: Jean Giraud  Originally Posted by: Karol_R  I'm looking for a way to represent the letter D as a subscript You can subscribe whatever. mysystem dot HelloGrandMa Hi, thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing. Davide sent the function shown above in which I need to use subscripts.
Joined: 10/12/2009(UTC) Posts: 289   Location: Cali, Colombia Was thanked: 124 time(s) in 83 post(s)
Joined: 28/08/2014(UTC) Posts: 1,510  Was thanked: 976 time(s) in 610 post(s)
Hi Karol. This could be a workaround, using the SMath Plot region. label.sm (7kb) downloaded 10 time(s). Best regards. Alvaro.
Subscripts in native Solver 30405. Collect as many the project needs, call the wanted by indexing. Maths Subscript.sm (11kb) downloaded 9 time(s).
Originally Posted by: Razonar  Hi Karol. This could be a workaround, using the SMath Plot region. label.sm (7kb) downloaded 10 time(s). Best regards. Alvaro. Wow great Alvaro. Thank you very much. I'm impressed.
Originally Posted by: Jean Giraud  Subscripts in native Solver 30405. Collect as many the project needs, call the wanted by indexing. Maths Subscript.sm (11kb) downloaded 9 time(s). Jean Giraud, Thank you too. But I have to put in some effort to understand what you sent. Kind regards
