Here it is. losa-forum.sm (863kb) downloaded 8 time(s).Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
Originally Posted by: GermanJG Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined". data not defined probably indicates some plugins not installed. Maybe other problems wrt your version.
Originally Posted by: GermanJG Here it is. Document does not open ... incorrect format
SMath Studio Desktop 64-bit Version: 1.0(build: 8348) Date: 9/11/2022 ConditionallyFormattedLabel: 1.0.8138.35454
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error. The same happens if you try to force a numerical evaluation using eval() Edited by user 17 January 2023 17:25:39(UTC)
Originally Posted by: Davide Carpi If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error. The same happens if you try to force a numerical evaluation using eval() That is it! As allways thanks!! But still don't understand why Jean files fails.
Originally Posted by: GermanJG SMath Studio Desktop 64-bit Version: 1.0(build: 8348) Date: 9/11/2022 Slide left the Formatted Label Side right the graph, remove the Σ no definido You should see the plot.
Originally Posted by: GermanJG That is it!
As allways thanks!! You're welcome! Originally Posted by: GermanJG But still don't understand why Jean files fails. There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file. If you remove the 3 inline evaluations it will work. Edited by user 17 January 2023 18:28:39(UTC)
My file can be an example of things NOT to do. Originally Posted by: Davide Carpi
Hi, Can we manage the units that are displayed? I have a load in kN/m2 and the result appears as kg/(m*s2). The idea is to present only positive values (with the appropriate unit). kind regards Conditionally Formatted Labels_unity.sm (6kb) downloaded 9 time(s).
The easier way might be something like this Code:press2text(x):line(concat(var2str(x/'kPa,1),"\0020\kN\002F\m\00B2\"),1,1)
Thank you very much. This is exactly what I needed.
Hi, I'm looking for a way to represent the letter D as a subscript. Unfortunately, Unicode doesn't seem to provide this option...
Is there any possibility to parameterize individual characters that will be presented?
Originally Posted by: Karol_R I'm looking for a way to represent the letter D as a subscript You can subscribe whatever. mysystem dot HelloGrandMa
Originally Posted by: Jean Giraud Originally Posted by: Karol_R I'm looking for a way to represent the letter D as a subscript You can subscribe whatever. mysystem dot HelloGrandMa Hi, thanks for the information, but I'm not sure if I expressed myself correctly. I mean the subscripts in the "phrases" that I marked in the drawing. Davide sent the function shown above in which I need to use subscripts.
Joined: 10/12/2009(UTC) Posts: 246 Location: Cali, Colombia Was thanked: 85 time(s) in 65 post(s)
Hi Karol. This could be a workaround, using the SMath Plot region. label.sm (7kb) downloaded 7 time(s).Best regards. Alvaro.
Subscripts in native Solver 30405. Collect as many the project needs, call the wanted by indexing. Maths Subscript.sm (11kb) downloaded 5 time(s).
Originally Posted by: Razonar Hi Karol. This could be a workaround, using the SMath Plot region. label.sm (7kb) downloaded 7 time(s).Best regards. Alvaro. Wow great Alvaro. Thank you very much. I'm impressed.
Originally Posted by: Jean Giraud Subscripts in native Solver 30405. Collect as many the project needs, call the wanted by indexing. Maths Subscript.sm (11kb) downloaded 5 time(s). Jean Giraud, Thank you too. But I have to put in some effort to understand what you sent. Kind regards
