Here it is. losa-forum.sm (863kb) downloaded 7 time(s).Sorry Jean but i don't understand what i'm supposed to see. I also get "data - not defined".
Joined: 04/07/2015(UTC) Posts: 6,323  Was thanked: 918 time(s) in 746 post(s)
Originally Posted by: GermanJG  Sorry Jean but I don't understand what I'm supposed to see. I also get "data - not defined". data not defined probably indicates some plugins not installed. Maybe other problems wrt your version.
Originally Posted by: GermanJG  Here it is. Document does not open ... incorrect format
 SMath Studio Desktop 64-bit Version: 1.0(build: 8348) Date: 9/11/2022 ConditionallyFormattedLabel: 1.0.8138.35454
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,532   Location: Italy Was thanked: 1269 time(s) in 834 post(s)
If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error. ![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45963&b=2) The same happens if you try to force a numerical evaluation using eval() ![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45965&b=2) Edited by user 17 January 2023 17:25:39(UTC)
Originally Posted by: Davide Carpi  If you hover over the asd definition you can see that there is an unsolved "d" dependancy that triggers the error. ![2023-01-17 15_10_16-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45963&b=2) The same happens if you try to force a numerical evaluation using eval() ![2023-01-17 15_23_37-SMath Solver - [losa-forum.sm_].png](/forum/resource.ashx?a=45965&b=2) That is it! As allways thanks!! But still don't understand why Jean files fails.
Originally Posted by: GermanJG  SMath Studio Desktop 64-bit Version: 1.0(build: 8348) Date: 9/11/2022 Slide left the Formatted Label Side right the graph, remove the Σ no definido You should see the plot.
Originally Posted by: GermanJG  That is it!
As allways thanks!! You're welcome! Originally Posted by: GermanJG  But still don't understand why Jean files fails. There is an excel data import at the begin of the file, is not related to the issue however so it doesn't matter. nevermind I was looking at your file. If you remove the 3 inline evaluations it will work. ![2023-01-17 16_28_05-SMath Solver - [Image Formated LABEL [Oxyhemoglobin] FORUM.sm].png](/forum/resource.ashx?a=45968&b=2) Edited by user 17 January 2023 18:28:39(UTC)
My file can be an example of things NOT to do. Originally Posted by: Davide Carpi
