26 Pages«<2021222324>»
#421 Posted : 31 January 2021 05:15:14(UTC)
Was thanked: 974 time(s) in 802 post(s)
1 Isolated M.sm (82kb) downloaded 20 time(s).
Offline netsonicyxf
#422 Posted : 31 January 2021 07:02:27(UTC)
netsonicyxf
all the math regions shows black.
How do you isolate M?
Edited by user 31 January 2021 07:04:26(UTC)  | Reason: Not specified
Offline Razonar
#423 Posted : 31 January 2021 08:14:23(UTC)
Razonar
Uruguay
Was thanked: 800 time(s) in 506 post(s)
Originally Posted by: netsonicyxf Go to Quoted Post
Why X-Y plot can't polt this, while plot 2D can?
Hi. In your case use eval() as in the image. After that XY plot works.
Offline netsonicyxf
#424 Posted : 31 January 2021 09:15:44(UTC)
netsonicyxf
This works for me, Thank you.
#425 Posted : 31 January 2021 14:23:48(UTC)
all black ... select all, background white.
Spool to file is most precious in many applications... here disabled.
Offline PompelmoTell
#426 Posted : 01 February 2021 11:49:18(UTC)
PompelmoTell
In fact it is a behavior that I did not expect. I noticed that you defined "M" symbolically. But it wasn't enough. With "eval" it works but I don't understand why
Offline uni
#427 Posted : 01 February 2021 12:10:14(UTC)
uni
Was thanked: 1257 time(s) in 732 post(s)
The problem is that the component is trying to determine the type of the expression and it doesn't do it correctly. This case has not yet been investigated by me. The return type is determined without evaluating the expression. When we forcibly evaluate an expression the component correctly recognizes its type.
I will try to expand the type of expressions supported.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline Razonar
#428 Posted : 01 February 2021 12:14:38(UTC)
Razonar
Uruguay
Hi Sergio. My interpretation, but not sure if it's actually the reason why. I think in terms of the Mathematica's Hold[x] instruction, or the equivalent Maple quoting with 'x'; those instructions make x remain unevaluated. In a mathematica procedure f(x), if previously you have x:=2 and call f[Hold[x+3]], f receive 'x+3' but not 5. SMath try to preserve all things unevaluated for make symbolic simplifications in cases of mixing symbolic and numeric calculations. For this is that XY plot and vectorize() function receive arguments unevaluated. In that sense eval() is the opposite to hold(), function that actually I ask for as feature suggestion.
The best example of that hold exists in SMath is the way that derivatives are evaluated, like in mathcad: you first define x:=2, then call diff(x^3,x) = 12. Notice that diff() don't receive 8 and 2 as arguments, but x^3 and x, just because you cant differentiate with something like diff(8,2). So, some functions in SMath gets it's arguments with 'hold', and it seems that vectorize() is another example, but others not.
Even that, also there are some other internals with an strange behavior for all functions: if you think that you write a function which goes to receive a big matrix as argument M, your first step in the body procedure must to be M:=M for ensure that it goes to be only numerical. Ndtma expose that in an example, but can't remember nor find where.
on 01/02/2021(UTC)
Offline Razonar
#429 Posted : 01 February 2021 12:31:47(UTC)
Razonar
Uruguay
Originally Posted by: uni Go to Quoted Post
... This case has not yet been investigated by me. ...
Hi Viacheslav: Just pay attention to the error message in the other post of the user with vectorize(): "t - not defined". This t is under an integral symbol. M remains unevaluated because depends on a numeric integral, which SMath try to retain unevaulated how long as can for avoid truncation errors in the same way that SMath do with pi or sqrt(2). So, if vectorize() can't deal with the numerical integral, I guess that it could be better to improve the general SMath way to determine when use the numeric value for all expressions and when retain the procedimental definition.
I guess that a way for uniformize SMath behaviors could be given checking Unknows() and IsDefined() procedures that not always agree for all expressions, and define some kind of standard way to check types in SMath. (I remember a post and a function plugin with a GetType() function too)
on 01/02/2021(UTC)
#430 Posted : 01 February 2021 15:48:55(UTC)
"eval" it works but I don't understand why sergio
eval("expression"Wink -
Converts the given expression from symbolic to numeric notation.
Being a function evaluation, it assigns to same name or another name.
Thus, by same token isolates and that's what X_Y wants, it wants its
own stuff [data, f(x), f(x,y) as 'f' for contour]
Within a for loop, it has the virtue of isolating internally
within the loop itself, then accelerates the for loop result.
It has the same effect as spooling to file, not confirmed Bible,
just from observation(s) ... forgive my Grand Discours made short.
Some functions that have only numeric parameters must be redefined
via the eval(,) to convert scalar 'x' for plotting on Quick plot @.
For instance: the Hypergeometric Gamma
on 01/02/2021(UTC)
Offline fedeghi
#431 Posted : 22 February 2021 13:41:54(UTC)
fedeghi
Was thanked: 24 time(s) in 16 post(s)
Hi, I was reading some old discussions about graphs plugin.. I ran into some posts anticipating the development of "setprop" command for X-Y Plot Region.
Is it in beta or is it released (I see it is available in the function lists, but I didn't understand if it is fully developed or still work in progress..)?
In case, does anybody have some examples of which parameters can be set and how? I mean, some guideline about syntax to be used?
Thanks
Bye
Offline uni
#432 Posted : 22 February 2021 17:10:47(UTC)
uni
This function works partially and does not completely cover the component (you can't change the properties of the curve with it). I do not recommend using it everywhere, because I am planning a more direct control mechanism.
You can find a usage example here and here.
Edited by user 22 February 2021 17:13:21(UTC)  | Reason: Not specified
Russia ☭ forever
on 22/02/2021(UTC)
Offline fedeghi
#433 Posted : 22 February 2021 18:41:35(UTC)
fedeghi
Ok uni, thanks for feedback.
I will follow your suggestion and wait for the new control method instead.
Offline GermanJG
#434 Posted : 29 April 2021 04:01:50(UTC)
GermanJG
Argentina
Hi, there is way to ratote the X axes values?
Offline MarB
#435 Posted : 29 April 2021 08:55:36(UTC)
MarB
You can set the maximum value on the x axis lower then the minimum value. Is that what you want to achieve?
But then the vertical grid lines are not adjusted correctly.
Offline GermanJG
#436 Posted : 29 April 2021 14:43:35(UTC)
GermanJG
Argentina
No, that didn't work.
I need to change the orientation of the text in x axes.
#437 Posted : 29 April 2021 16:00:44(UTC)
Originally Posted by: GermanJG Go to Quoted Post
Hi, there is way to rotate the X axes values ?
You can rotate ...
1. A discretized function [2 cols]
2. A drawing in 2 cols
3. Smath 3 D CreateMesh
4. RGB matrix
5. plot ortho on isometric X_Y plot
Offline mkraska
#438 Posted : 29 April 2021 23:50:13(UTC)
mkraska
Was thanked: 1098 time(s) in 701 post(s)
I think it is about rotating the tick labels on the x axis such that they don't overlap.
Unfortunately this is not possible, at least not exposed to the settings interface.
You could, however, change number format and tick spacing to mitigate the problem.
If the maxima plugin is an option for you, then you can use the draw library.
Blatt1.sm (15kb) downloaded 18 time(s).
Offline GermanJG
#439 Posted : 04 May 2021 00:29:22(UTC)
GermanJG
Argentina
That is exactly what I need.
I tried before doing what you suggest but i need them in a determine spacing and they sometimes overlap.
I will try with the maxima plugin.
Viel danke.
PD: the thanks button throws me an error.
Offline ndtma
#440 Posted : 10 May 2021 07:05:01(UTC)
ndtma
Sri Lanka
Was thanked: 124 time(s) in 82 post(s)
Originally Posted by: alyles Go to Quoted Post
Updated my snippet for the XY Plot setprop wrappers. I have functions for each property that can be set with setprop.
In latest SS 99.7799, I experience a label error similar to image as shown.
Some previous files show this error.
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
