16 Pages«<1112131415>»
Offline mkraska
#241 Posted : 7 years ago
mkraska
Extension manager conflicts should be resolved by now.
Offline Andrea993
#242 Posted : 7 years ago
Andrea993
Rank: Member
We really need a linux port
Offline mkraska
#243 Posted : 7 years ago
mkraska
I agree. Maybe, just an adjustment of the command line for establishing the socket connection is required. Under Windows I use
maxima-installation-path/bin/maxima.bat -l sbcl -s <port number>
This requires
- the .net socket stuff and process control to work under mono,
- a unicode-proof lisp compiler to be installed (which accepts utf-8 socket encoding), under win the only one is steel bank common lisp (SBCL).
Also, I need to know the name of the maxima process for detection of active maxima processes via System.Diagnostics.Process.GetProcessesByName(name). This is required to identify the pid for later kill. Under windows this might be "maxima" or "lisp" or "sbcl". This has changed over the years and may be different under linux.
The plugin might work even as it is, if the maxima startup script is renamed to maxima.bat.
Any information from the linuxing SMatheers is welcome.
BTW, there is a maxima build for android as well...
EDIT: It would also help, if someone could explain me how to build and debug the plugin under Linux. Under Win, I use VS 2015 with the project as found in the SVN repository. Otherwise I need to blindly make changes under win and install and test under linux. This would be a huge drawback compared to the win-only workflow, where compiling and running SMath with the new build in the debugger is just a push of a single button...
Edited by user 7 years ago  | Reason: Not specified
Offline mkraska
#244 Posted : 7 years ago
mkraska
I just did some tests on a linux mint 17.2 virtual box with smath 6654:
install maxima, copy /usr/bin/maxima to /usr/bin/maxima.bat
Insert> maxima> settings: Path to maxima: /usr/bin
Then smath crashes with the following console output. Understanding this is beyond my experience level in c#.
Offline Andrea993
#245 Posted : 7 years ago
Andrea993
Rank: Member
System.IO.DirectoryNotFoundException: Could not find a part of the path "/home/user/.config/SMath/extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41/maxima.xml".
at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean anonymous, FileOptions options) <0x7fb8bb55d1f0 + 0x001f4> in <filename unknown>:0
at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options) <0x7fb8bb55cf60 + 0x0004d> in <filename unknown>:0
at System.IO.FileStream..ctor (System.String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, Boolean useAsync) <0x7fb8bb55cf00 + 0x00051> in <filename unknown>:0
at (wrapper remoting-invoke-with-check) System.IO.FileStream:.ctor (string,System.IO.FileMode,System.IO.FileAccess,System.IO.FileShare,int,bool)
at System.Xml.XmlWriterSettings.CreateWriter (System.String outputFileName) <0x417801b0 + 0x000af> in <filename unknown>:0
[/SPOILER]
The path is a mix of windows and linux style: "/home/user/.config/SMath/extensions\plugins\44011c1e-5d0d-4533-8e68-e32b5badce41/maxima.xml" plugin should be use '/' instead '\'
Btw I suggest you to link maxima.bat to maxima instead of make a copy
Code:
sudo ln -s /usr/bin/maxima /usr/bin/maxima.bat
On linux an IDE similar to visual studio is "visual studio code" also by MS, you can use it with C# extension
thanks 1 user thanked Andrea993 for this useful post.
on 14/09/2018(UTC)
Offline mkraska
#246 Posted : 7 years ago
mkraska
Code:
Thanks for the comment. Seems that fixing the path separator might be a goot starting point. There must be something like SystemPathSeparator in C#, I shall find out...
Also, I shall get a more recent linux virtual box with enough space to install VS code.
Offline Andrea993
#247 Posted : 7 years ago
Andrea993
Rank: Member
Code:
If you public (is it already?) the code I can also give you an hand.
If you make a new virtual machine maybe is better that you use Ubuntu to develop that is ~more standard~
Offline mkraska
#248 Posted : 7 years ago
mkraska
Third party SMath plugins are always open source. Here is the link for the Maxima plugin.
Feel free to play around with it. I guess one of the first steps will be to make the VS sln file fit for cross platform portability.
And we will need to set up a utf-8 maxima binary under linux. Under windows this is SBCL. It is available under linux as well but on my box this requires separate compilation.
BTW, Davide has offered help with streamlining the install procedure (automated maxima installation). I guess that the BTS issue SS-3562 is the right place for further discussion and co-ordination.
Ubuntu is fine for me.
Offline mkraska
#249 Posted : 7 years ago
mkraska
Plugin updated. Mainly cosmetic changes.
Update19.sm (329kb) downloaded 56 time(s).
thanks 3 users thanked mkraska for this useful post.
on 18/09/2018(UTC),  on 18/09/2018(UTC),  on 18/09/2018(UTC)
Offline mkraska
#250 Posted : 7 years ago
mkraska
Example application for Fit(), MSE() and Residuals() and efficient plotting.
Example Fit.sm (14kb) downloaded 53 time(s).
on 22/09/2018(UTC),  on 22/09/2018(UTC),  on 22/09/2018(UTC)
Offline omorr
#251 Posted : 7 years ago
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
Thank you Martin,
I tested it briefly with a larger data set and more than one dependent variable. At a first glance it seems that it works surprisingly fast. I might have forgotten but I think there is not yet a strictly numerical procedure in SMath (available via plugin) for nonlinear fitting a quite large data set to a function with multiple dependent variables.
Offline Razonar
#252 Posted : 7 years ago
Razonar
Uruguay
Was thanked: 990 time(s) in 618 post(s)
In the attached, the functional version of the Carlos' version of LM. For some large set of data, as Omorr ask, the main problem it's the Jacobian. There are some algorithms that don't use it. In this approach, actually it's a truly mix of numerical and symbolic manipulation for the Jacobian.
lmCarlos.sm (58kb) downloaded 51 time(s).
Offline mkraska
#253 Posted : 6 years ago
mkraska
Severe problems since SMath build 6970. Last version tested ok is 6965.
maximaproblem.sm (5kb) downloaded 26 time(s).
Offline omorr
#254 Posted : 6 years ago
omorr
Serbia
Confirmed, I think...
Offline andrbig77
#255 Posted : 6 years ago
andrbig77
Hello SMath-Team,
I confirmed, it confuses me too
Best regards,
Andrey
Offline omorr
#256 Posted : 6 years ago
omorr
Serbia
The problem remained unsolved
However, it seems that Det(),Diff(),Int(),Lim(),Sum() are working well.
#257 Posted : 6 years ago
Int() certainly does not work.
Why bother Maxima, unless some like that cluster fuck
Online Andrey Ivashov
#258 Posted : 6 years ago
Was thanked: 2012 time(s) in 680 post(s)
Plugin updated. Please try.
on 06/03/2019(UTC),  on 06/03/2019(UTC)
Offline omorr
#259 Posted : 6 years ago
omorr
Serbia
I think it is all right now. Thank you.
Offline mkraska
#260 Posted : 6 years ago
mkraska
I confirm that the API issues seem to be resolved. Andrey, thank you very much, I might not have been able to fix that soon.
In the test suite (Plugin maxima test.sm in the interactive handbook) there is just a new issue with displaying svg images in the Maxima-Draw-Region and in the image region. PDF and PNG work fine though.
Best regards, Martin
Similar Topics
Error implementing ToolboxGroup for the maxima plugin (Questions)
by fakemoses 2 years ago
Maxima Plugin Feedback Survey: Share Your Ideas and Report Bugs (Feature Requests)
MAXIMA PLUGIN expand (Questions)
by Angel695 2 years ago
Solve Function Stuck (46/47) with Maxima Plugin (Questions)
by Albedo 3 years ago
[Maxima Plugin] Text exportation issue (Questions)
by SteelCat 3 years ago
Maxima Plugin problem (Bugs & Problems)
by FT_PENG 3 years ago
Text characters not passing correctly to Maxima plugin (Bugs & Problems)
by gurro 4 years ago
[Maxima Plugin] is a custom Maxima function call-able in SMath (Questions)
by 007.000 7 years ago
[Maxima Plugin] least common multiple (Questions)
news for Maxima Plugin (Questions)
by oscampo 9 years ago
Maxima plugin error (Bugs & Problems)
by olik 9 years ago
