Offline 007.000
#1 Posted : 22 May 2018 13:06:49(UTC)
007.000
Rank: Member
I have defined a function in Maxima but am unable to call it in SMath... I've searched around and tried a bunch of different syntaxes buy am still new to this so if it does indeed work I couldn't get it going... Any help would be appreciated.
Attached are the Maxima .mac file and the SMath file attempting to call it.
func_gradient_divergence_curl.7z (1kb) downloaded 50 time(s).
calling custom Maxima function.sm (5kb) downloaded 67 time(s).
Edited by moderator 22 May 2018 13:21:45(UTC)  | Reason: added Maxima tag
#2 Posted : 22 May 2018 16:04:58(UTC)
Forget what does not work outside of native Smath
Maths Grad_Div_Curl.sm (13kb) downloaded 51 time(s).
#3 Posted : 22 May 2018 16:50:39(UTC)
Jacob.sm (54kb) downloaded 43 time(s).
Offline mkraska
#4 Posted : 22 May 2018 19:32:17(UTC)
mkraska
It seems that there is a conflict with the vector package (load(vect) is executed at maxima startup in the plugin). If you remove that call, then your macro is loaded. I only tried this in wxmaxima. See Insert> Maxima> Log> wxm to see what the plugin does at startup.
