Online scb
#1 Posted : 10 April 2009 17:02:37(UTC)
scb
I often have to compute the net present value of monthly payments of say 100,00 kr. on 240 consecutive months with an interest rate of 0,05% pr year.
In SMATH the summation goes from k=1 to k=240 of the calculation -100/(1+0,05/12)^k, and the result is
-21063,356, but the same calculation in MathCad and Excel computes to -15152,53.
It seems that the summation is correct in the interval k=1 to k=130, but from 131 upwards the calculation is
increasingly wrong compared to MathCad's solution.
The counter variable seems correct, so I can't figure out what goes wrong. Is there a problem or am I mistreating the program in some way (like I did with the "solve" function)?
I tried the same summation with the for-loop, and got the same result (-21063,356), and also found that the for-loop summation is correct up to 130 as the upper limit of the loop-counter.
Edited by user 10 April 2009 17:15:55(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#2 Posted : 10 April 2009 19:26:09(UTC)
Was thanked: 1954 time(s) in 658 post(s)
Hello. Thank you! Observation reproduced. This will be fixed in 1-2 days and fix will be available in next version of SMath Studio (on the end of April).
Similar Topics
Summation Equivalent (Questions)
by ianlh 09/12/2021 15:10:03(UTC)
Output summation function elements into array / vector (Questions)
by jdoe1 02/01/2020 06:49:14(UTC)
Summation of log functions (Questions)
by ianlh 20/10/2019 15:20:14(UTC)
Integrating summations (Questions)
by Camden 21/02/2019 00:47:27(UTC)
Summation error - imaginary i as sum iterator (Bugs & Problems)
by janclaeys 18/03/2018 23:55:24(UTC)
Summation of odd numbers to infinity (Questions)
by RFreund 21/08/2016 04:30:00(UTC)
Error of a function with Summation (Questions)
by Novice 17/05/2016 21:15:15(UTC)
[SS-1249] Summation in For Loop (Bugs & Problems)
by RFreund 01/12/2014 00:25:47(UTC)
matrix and summation (Questions)
by arts1983 17/05/2012 13:19:55(UTC)
summation operator sum(1) ? (Feature Requests)
by omorr 06/04/2012 00:53:29(UTC)
summation operator question? (Bugs & Problems)
by omorr 16/02/2012 12:22:29(UTC)
Summation of Matrices (Bugs & Problems)
by rsunny 13/02/2011 16:20:45(UTC)
Problem with summation 2 (Bugs & Problems)
by Guest 11/01/2011 04:47:49(UTC)
Problem with summation (Bugs & Problems)
by TheWizEd 09/01/2011 18:30:22(UTC)
Summation ..is possible to summ for values of i even ( odd )? (Questions)
by frapuano 29/11/2010 16:18:58(UTC)
