SMath Studio Forum
Bugs & Problems
Summation error - imaginary i as sum iterator
Joined: 05/10/2016(UTC) Posts: 22 Was thanked: 2 time(s) in 2 post(s)
Dear all, Some years ago, I worked out a beam calculation tool in smath, based on singularity functions. The sheet worked flawless in an older SMath version, but the most recent SMath-incarnations result in problems: the error seems to originate with the summation command. How do I get this program working again? I attach the original files: thanks for any feedback! Kind regards from a Belgian SMath-fan, Jan Original file with summation error.sm (144kb) downloaded 22 time(s). Original file working.pdf (191kb) downloaded 27 time(s).Edited by moderator 29 March 2018 12:45:53(UTC)
| Reason: Not specified
Hello. This is because of using "i" as a variable. Currently we have some issues regarding it. Will be addressed soon. Simple change to fix your worksheet: Best regards.
Simple change to fix your worksheet: Alternately: define the summations as local variable [SS 6179] The document concludes the project. Jean Original file with summation error(1).sm (148kb) downloaded 28 time(s).
Thank you Andrei & Jean for the fast feedback!
SMath Studio Forum
Bugs & Problems
