Offline Novice
#1 Posted : 17 May 2016 21:15:15(UTC)
Novice
Rank: Member
Korea, Republic Of
Hi!
I'm a novice for SMath.
I'm porting a Mathcad 15 file to SMath.
I found that the SMath function with Summation has some error.
There are difference between the output of direct calculation and function output.(See attached pictures)
Please, check it and help me.
Best regards,
Novice
question01.sm (8kb) downloaded 25 time(s).Smath_Summation_Error.JPGMathcad15_out.JPG
Offline Ernesto
#2 Posted : 17 May 2016 22:34:32(UTC)
Ernesto
Nicaragua
Was thanked: 13 time(s) in 11 post(s)
Looks like a bug. If you right click DD(0), and change the optimization to symbolic, it gives the right answer.
thanks 1 user thanked Ernesto for this useful post.
on 18/05/2016(UTC)
#3 Posted : 18 May 2016 05:45:38(UTC)
Define as a function of an argument and use eval(,)
Offline Novice
#4 Posted : 18 May 2016 07:32:05(UTC)
Novice
Rank: Member
Korea, Republic Of
Thank you!
Whenever I got'the error message, "Result is above max. allowed positive number", I'll try to change the option.
Offline Novice
#5 Posted : 18 May 2016 07:52:56(UTC)
Novice
Rank: Member
Korea, Republic Of
Thank you Jean, it is great hint for me.
I've tried to use 'eval' function for the output of summation function as like you.
But I got another results.(See attached sample file)
Would you mind check and help me?
Edited by user 18 May 2016 08:50:05(UTC)  | Reason: Not specified
#6 Posted : 18 May 2016 17:56:47(UTC)
You forgot to index λ
on 19/05/2016(UTC)
Offline Novice
#7 Posted : 19 May 2016 00:58:15(UTC)
Novice
Rank: Member
Korea, Republic Of
Dear Jean,
Thank you very much for kind correction!
Your timely comments enlightened me in the darkness!!
Clap Clap
