SMath Studio Forum
Questions
Summation of odd numbers to infinity
I am trying to use some internal force and deflection tables from a textbook for plates. Attached are the equations for moment, shear, deflection, etc. Is it possible for me to write this equation using double summation and the constants for m, n which are odd numbers to infinity? Thanks in advance! WP_20160820_20_06_00_Pro.jpg (3,596kb) downloaded 57 time(s). WP_20160820_20_06_36_Pro.jpg (3,447kb) downloaded 35 time(s).
Joined: 17/01/2013(UTC) Posts: 296 Location: Khabarovsk, Russia Was thanked: 151 time(s) in 107 post(s)
Just curious: if done manually, does it require as little as infinite number of calculations? (a tip: the sum members are infinitely small numbers) Edited by user 21 August 2016 04:47:39(UTC)
Best regards, Mike Kaganski |
Sure. Just take odd numbers. Best regards. Alvaro.
Thanks for the help. Not sure why I got so hung up on this. Seems relatively easy now... Edited by moderator 28 August 2016 16:08:08(UTC)
| Reason: marked as Solved
SMath Studio Forum
Questions
