Hi, I am trying to convert a Mathcad 15 sheet, and have a problem with the below equation: Is there a summation within Smath that will do the second summation? From the Mathcad help: Thanks in advance Ian
Hi. There are not equivalent, but this is how to convert it into usual summation operator. Best regards. Alvaro.
Still cant get it to work, I will strip out the identifying material and post the worksheet.
Thanks Ian
Originally Posted by: ianlh Attached is sheet, this is a MRM for beam frequency analysis Sum over 'n' ... NOT over 'k' Model summation attached. Function Running Summation.sm (33kb) downloaded 10 time(s).
Originally Posted by: ianlh Attached is sheet, this is a MRM for beam frequency analysis Better to attach the original Mathcad document. |
Mathcad sheet attached, striped version beam frequency test 2.xmcd (172kb) downloaded 10 time(s).Jean, I am at a loss as to which part of your file I should be looking at. Ian
Hi. As Viacheslav says, it's better in this case the mathcad file. Just a couple of notes. You use a for loop with i as counter. Thus, at the exit, i equals the last count value, not the entire range. So, or you redefine i as range, or use this way for not changing i value Actually, SMath doesn't have "range" variables, it only have scalars and matrices. But mathcad have "true" range variables, which it's more a complication than an adventage. BTW in SMath you can't use a range variable in the same way, and sometimes needs some dummy variable for detect them Finally, remember that in mathcad sqrt(-1) is 1i, but in SMath it is just i, so using is as counter you loose all the complex algebra. Bests regards. Alvaro.
Originally Posted by: ianlh Jean, I am at a loss as to which part of your file I should be looking at. It just shows how to run summation wrt several dependent functions.
Hi Alvaro,
Some interesting hints there. I imagine its also the same going the other way.
Hi Jean,
OK, now I understand, just some pointers for me
Thanks Ian
Originally Posted by: ianlh Hi Jean, OK, now I understand, just some pointers for me Thanks Ian The A,B are numerical two vectors of coefficients. Then introduced in the scalar function wrt sin/cos.
Originally Posted by: ianlh I am trying to convert a Mathcad 15 sheet, and have a problem with the below equation: I think that there should be such a replacement. |
You can use debugging in both programs to check that the functions are working correctly. |
Thanks for the pointers, will revisit tomorrow
Ian
