26 Pages123>»
Offline uni
#1 Posted : 26 April 2013 16:20:32(UTC)
uni
Was thanked: 1257 time(s) in 732 post(s)
X-Y Plot Region
SMath Studio compatibility SMath Viewer compatibility mono compatibility Extension page Sources
XYPlot. Examples.sm (31kb) downloaded 1,276 time(s).
XYPlot. Examples.pdf (155kb) downloaded 1,267 time(s).
XYPlot. Demo.sm (6kb) downloaded 635 time(s).
XYPlot. Demo.pdf (46kb) downloaded 694 time(s).
XYPlot. Text labels.sm (11kb) downloaded 451 time(s).
XYPlot. Text labels.pdf (54kb) downloaded 388 time(s).
XYPlot. Fill area.sm (11kb) downloaded 421 time(s).
XYPlot. Fill area.pdf (85kb) downloaded 353 time(s).
XYPlot. Draw shapes.sm (20kb) downloaded 651 time(s).
XYPlot. Draw shapes.pdf (93kb) downloaded 491 time(s).
XYPlot. Linear polar.sm (57kb) downloaded 201 time(s).
XYPlot. Linear polar.pdf (135kb) downloaded 128 time(s).
3D plots in XY Plot plugin
pMesh.sm (245kb) downloaded 292 time(s).
pMesh.pdf (3,117kb) downloaded 304 time(s).
Functions for grids, meshes and plot surfaces. Support triangular meshes and multiple surfaces in the same plot.
pSurf.sm (316kb) downloaded 66 time(s).
pSurf.pdf (2,254kb) downloaded 52 time(s).
Small piece of code for filled 2-D contour plot in the XY plot plugin.
FillContour.sm (35kb) downloaded 212 time(s).
FillContour.pdf (307kb) downloaded 211 time(s).
Note: '~' is used as a mark for the "range" variable and should only be used inside the X-Y Plot.
Click to enlarge
XYPlot.%20Parametric.sm
Links:
1. Dr. Xu's Books .
2. Creating charts & graphics without coding .
Edited by user 18 April 2023 15:58:50(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 13 users thanked uni for this useful post.
on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 26/04/2013(UTC),  on 29/04/2013(UTC),  on 12/05/2013(UTC),  on 13/07/2013(UTC),  on 17/01/2016(UTC),  on 03/12/2016(UTC),  on 11/12/2017(UTC),  on 22/09/2021(UTC),  on 29/08/2022(UTC)
Offline mkraska
#2 Posted : 26 April 2013 16:38:29(UTC)
mkraska
Was thanked: 1098 time(s) in 701 post(s)
Здорово!
I tried some functions (typed to the placeholder):
x - nothing happens
sin(x) - works
ln(x) - crash (perhaps due to undefined values)
any undefined function - crash
previously defined function returning a list - GUI freeze
Edited by user 26 April 2013 17:30:33(UTC)  | Reason: Not specified
#3 Posted : 26 April 2013 17:23:34(UTC)
Was thanked: 1320 time(s) in 871 post(s)
Nice work uni Clap
Originally Posted by: uni Go to Quoted Post
You can change only the function for now. Need to figure out a way how to pass parameters to display the graph or do it like in Mathcad.
A way could be to use context menu items (see ConstructorRegion plugin by Andrey)... also the Mathcad mode it's quite interesting...
you can post the plugin code?
Edited by user 26 April 2013 17:25:56(UTC)  | Reason: Not specified
Offline omorr
#4 Posted : 26 April 2013 17:46:39(UTC)
omorr
Serbia
This is a long time waiting feature and I think we are all excited about it Good
Good luck uni Victory
EDIT: I tried it a bit in a "faulty" Mono in Xubuntu. It si working initially although with crashes as Martin mentioned
Edited by user 26 April 2013 17:49:22(UTC)  | Reason: Not specified
Offline uni
#5 Posted : 26 April 2013 17:47:33(UTC)
uni
The code is taken from this book:
C# Application Series - Xu J. - Practical C# Charts and Graphics [2007, PDF, ENG] (link, rus).
I have something removed and added something to get the plugin. I added sources.
mkraska, not so fast Acute Try some number.
Edited by user 26 April 2013 17:57:54(UTC)  | Reason: Not specified
Russia ☭ forever
on 26/04/2013(UTC),  on 22/07/2013(UTC)
#6 Posted : 26 April 2013 18:02:04(UTC)
Thank you very much both for the sources and the book Biggrinrinks:
[EDIT] plugins on wiki updated
Edited by user 26 April 2013 18:34:02(UTC)  | Reason: Not specified
Offline kilele
#7 Posted : 26 April 2013 18:45:46(UTC)
kilele
thank you very much uni!
please look at this post:
http://en.smath.info/for...provements.aspx#post9105
ZedGraph is c# targeting .net20 so it should work both in windows and linux.
Offline Basile
#8 Posted : 26 April 2013 18:56:51(UTC)
Basile
Was thanked: 8 time(s) in 7 post(s)
Thank you uni.
This is long overdue.
As you develop it, please have in mind the basic form of axes: Lin-Lin, Lin-Log, Log-Log.
Basile
Offline omorr
#9 Posted : 26 April 2013 19:45:04(UTC)
omorr
Serbia
...Try some number.
Good
Offline Basile
#10 Posted : 26 April 2013 22:22:17(UTC)
Basile
Radovan,
How did you put graph title and axis titles? and axes greater than 1.
Thank you,
Basile
Offline uni
#11 Posted : 26 April 2013 22:58:45(UTC)
uni
Updated. Form formatting is added to the context menu. Changes take effect after the recalculation. You can use system for several functions but be careful (not tested yet).
Russia ☭ forever
on 27/04/2013(UTC),  on 27/04/2013(UTC)
Offline omorr
#12 Posted : 26 April 2013 23:39:18(UTC)
omorr
Serbia
Hello Basile
I did nothing else just put a number in the function placeholder, as uni said. It seems that uni just put this example just as a test at the moment.
Lots of user feedback in quite a short time shows that we are very interested in this plugin. It seems that we need to have some more patience until the very appreciated plugin like this become more stable Beta , and than to test it more carefully Good
Offline kaka
#13 Posted : 27 April 2013 09:14:52(UTC)
kaka
Rank: Member
Clap Thank you again.
Last update: XYPlotRegion_20130427.zip
Sources: https://smath.info/svn/p...ic/plugins/XYPlotRegion/
Offline uni
#14 Posted : 27 April 2013 12:54:43(UTC)
uni
Updated.
Edited by user 27 April 2013 16:15:16(UTC)  | Reason: Not specified
Russia ☭ forever
thanks 5 users thanked uni for this useful post.
on 27/04/2013(UTC),  on 27/04/2013(UTC),  on 27/04/2013(UTC),  on 27/04/2013(UTC),  on 28/04/2013(UTC)
Offline pol1
#15 Posted : 28 April 2013 08:49:03(UTC)
pol1
Thanks.
The traces & Number Format function is not working for me (Win 7 64 Bit).
Offline mkraska
#16 Posted : 28 April 2013 10:01:32(UTC)
mkraska
Updated.
The last update seems to focus on handling lists of plots. The plugin seems to be under heavy construction.
For plotting functions, the xyplotrregion just evaluates the name, without caring for the argument, therefore plotting pure expressions just as x or x^2 fails.
Also, numbers must be pure numbers, not expressions that can be evaluated to numbers.
I guess that the built-in demo shows sort of development target. It would be interesting to know if expression input for plot items and range limits including unit handling are on the agenda. Anwyway, I am looking forward to the next release.
Offline uni
#17 Posted : 28 April 2013 13:13:01(UTC)
uni
Originally Posted by: pol1 Go to Quoted Post
Thanks.
These tabs will be added later. Working on it.
Updated.
Edited by user 28 April 2013 14:48:41(UTC)  | Reason: Not specified
Russia ☭ forever
on 28/04/2013(UTC),  on 28/04/2013(UTC)
Offline mkraska
#18 Posted : 28 April 2013 15:48:50(UTC)
mkraska
Updated.
Crashing xyplot:
- loading documents created with earlier versions of the plugin
- expressions evaluating to lists but not being lists (e.g. ±1)
Not crashing xyplot:
- using units Clap
empty placeholder produces a line y=x
Is using limit expressions including units (perhaps using placeholders as in old mathcad) on the agenda?
on 28/04/2013(UTC)
Offline uni
#19 Posted : 28 April 2013 17:32:00(UTC)
uni
There is only one placeholder, so I can enter only the expression and nothing more. I don't know whether it is possible to add more placeholders. Limits for the graphs need to be set explicitly (in the formatting dialog).
Russia ☭ forever
Offline mkraska
#20 Posted : 28 April 2013 19:26:50(UTC)
mkraska
Could global variables be an option?
The user might define or display values of settings like
XYPlot.xmin:0
XYPlot.xmax:3'm -> this would give the independent variable a unit
XYPlot.ymin:0
XYPlot.ymax:"auto" (auto-scaling)
XYPlot.xaxis:"log" or "lin"
XYPlot.title:num2str(n)
XYPlot.xtics:0,5*'m
etc. This would be quite transparent and readable, but could be hidden in collapsable regions if required.
Settings in the context menu might change or override the variable values or restore them to defaults.
Units could be automatically added to the default axis label if appropriate. You could, however, leave proper annotation in the user's responsibility.
Sticking to some naming convention (e.g. gnuplot) would facilitate the usage.
on 03/06/2013(UTC)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 24/06/2018 06:00:49(UTC)
X-Y Plot Region Plugin Problem (Questions)
by ndtma 20/06/2018 19:38:44(UTC)
26 Pages123>»
