  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,640   Was thanked: 1400 time(s) in 817 post(s)
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
 14 users thanked uni for this useful post.
on 26/04/2013(UTC), on 26/04/2013(UTC), on 26/04/2013(UTC), on 26/04/2013(UTC), on 26/04/2013(UTC), on 29/04/2013(UTC), on 12/05/2013(UTC), on 13/07/2013(UTC), on 17/01/2016(UTC), on 03/12/2016(UTC), on 11/12/2017(UTC), on 22/09/2021(UTC), on 29/08/2022(UTC), on 13/01/2024(UTC)
Joined: 15/04/2012(UTC) Posts: 2,046  Was thanked: 1177 time(s) in 752 post(s)
Здорово! I tried some functions (typed to the placeholder): x - nothing happens sin(x) - works ln(x) - crash (perhaps due to undefined values) any undefined function - crash previously defined function returning a list - GUI freeze Edited by user 26 April 2013 17:30:33(UTC)
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,728   Location: Italy Was thanked: 1396 time(s) in 910 post(s)
Nice work uni Originally Posted by: uni  You can change only the function for now. Need to figure out a way how to pass parameters to display the graph or do it like in Mathcad. A way could be to use context menu items (see ConstructorRegion plugin by Andrey)... also the Mathcad mode it's quite interesting... you can post the plugin code? Edited by user 26 April 2013 17:25:56(UTC)
  Rank: Administration Groups: Registered, Advanced Member Joined: 23/06/2009(UTC) Posts: 1,740   Was thanked: 319 time(s) in 268 post(s)
This is a long time waiting feature and I think we are all excited about it Good luck uni Radovan EDIT: I tried it a bit in a "faulty" Mono in Xubuntu. It si working initially although with crashes as Martin mentioned Edited by user 26 April 2013 17:49:22(UTC)
The code is taken from this book: C# Application Series - Xu J. - Practical C# Charts and Graphics [2007, PDF, ENG] ( link, rus). I have something removed and added something to get the plugin. I added sources. mkraska, not so fast  Try some number. Edited by user 26 April 2013 17:57:54(UTC)
on 26/04/2013(UTC), on 22/07/2013(UTC)
Thank you very much both for the sources and the book  rinks: [EDIT] plugins on wiki updated Edited by user 26 April 2013 18:34:02(UTC)
Was thanked: 133 time(s) in 114 post(s)
Was thanked: 8 time(s) in 7 post(s)
Thank you uni. This is long overdue. As you develop it, please have in mind the basic form of axes: Lin-Lin, Lin-Log, Log-Log.
Basile
Originally Posted by: uni  ...Try some number. Regards, Radovan omorr attached the following image(s): |
Radovan,
How did you put graph title and axis titles? and axes greater than 1.
Thank you, Basile
Updated. Form formatting is added to the context menu. Changes take effect after the recalculation. You can use system for several functions but be careful (not tested yet). |
on 27/04/2013(UTC), on 27/04/2013(UTC)
Hello Basile Originally Posted by: Basile  How did you put graph title and axis titles? and axes greater than 1. I did nothing else just put a number in the function placeholder, as uni said. It seems that uni just put this example just as a test at the moment. Lots of user feedback in quite a short time shows that we are very interested in this plugin. It seems that we need to have some more patience until the very appreciated plugin like this become more stable  , and than to test it more carefully Regards, Radovan |
 Thank you again. Originally Posted by: uni
Updated.  Edited by user 27 April 2013 16:15:16(UTC)
 5 users thanked uni for this useful post.
on 27/04/2013(UTC), on 27/04/2013(UTC), on 27/04/2013(UTC), on 27/04/2013(UTC), on 28/04/2013(UTC)
Thanks. The traces & Number Format function is not working for me (Win 7 64 Bit).
Originally Posted by: uni  Updated. The last update seems to focus on handling lists of plots. The plugin seems to be under heavy construction. For plotting functions, the xyplotrregion just evaluates the name, without caring for the argument, therefore plotting pure expressions just as x or x^2 fails. Also, numbers must be pure numbers, not expressions that can be evaluated to numbers. I guess that the built-in demo shows sort of development target. It would be interesting to know if expression input for plot items and range limits including unit handling are on the agenda. Anwyway, I am looking forward to the next release. mkraska attached the following image(s): |
Originally Posted by: pol1  Thanks. The traces & Number Format function is not working for me (Win 7 64 Bit). These tabs will be added later. Working on it. Updated.  Edited by user 28 April 2013 14:48:41(UTC)
on 28/04/2013(UTC), on 28/04/2013(UTC)
Crashing xyplot: - loading documents created with earlier versions of the plugin - expressions evaluating to lists but not being lists (e.g. ±1) Not crashing xyplot: - using units empty placeholder produces a line y=x Is using limit expressions including units (perhaps using placeholders as in old mathcad) on the agenda? mkraska attached the following image(s): |
There is only one placeholder, so I can enter only the expression and nothing more. I don't know whether it is possible to add more placeholders. Limits for the graphs need to be set explicitly (in the formatting dialog). |
Could global variables be an option?
The user might define or display values of settings like XYPlot.xmin:0 XYPlot.xmax:3'm -> this would give the independent variable a unit XYPlot.ymin:0 XYPlot.ymax:"auto" (auto-scaling) XYPlot.xaxis:"log" or "lin" XYPlot.title:num2str(n) XYPlot.xtics:0,5*'m
etc. This would be quite transparent and readable, but could be hidden in collapsable regions if required. Settings in the context menu might change or override the variable values or restore them to defaults. Units could be automatically added to the default axis label if appropriate. You could, however, leave proper annotation in the user's responsibility.
Sticking to some naming convention (e.g. gnuplot) would facilitate the usage.
