Joined: 22/02/2023(UTC) Posts: 34 Location: Seoul Was thanked: 1 time(s) in 1 post(s)
I would like to have a function like lookup (vlookup, hlookup) in smath. thank you. bar size.sm (7kb) downloaded 11 time(s).
1 user thanked soomoon for this useful post.
Joined: 12/02/2018(UTC) Posts: 62 Location: Belém Was thanked: 7 time(s) in 6 post(s)
findrows function within Special Functions plugin is what you're looking for, soomoon
Originally Posted by: soomoon I would like to have a function like lookup (vlookup, hlookup) in smath. Find Index Key Code is lot more powerful. Assume your Customer wants more information from his bar diameter you can give all pertaining informations ... Add price column, material, delivery ... etc. Cheers ... Jean bar size Findndex KeyCode.sm (11kb) downloaded 36 time(s).
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
1 user thanked ndtma for this useful post.
Jean, your example shows EXACTLY what findrows does.
Originally Posted by: joaobr Jean, your example shows EXACTLY what findrows does Yes for that simple application. FindIdx(V,x,col) gives me more for advanced Engineering works Thanks for the observation.
Joined: 23/07/2013(UTC) Posts: 1,130 Was thanked: 510 time(s) in 340 post(s)
findrows() function revisited. As a part of a project undertaken to study flows of some perennial streams in Sri Lanka, a particular stream, located far away from Colombo, was selected and a Rating Table (RT) was prepared relating water levels to flows. This process took a few years so that the data would almost cover reasonable range of depths for practical reasons, excluding severe floods. During this period, an electronic device was also constructed to measure water levels (WL) and transmit as digital signals to control station in Colombo. However, the numerical values of transmitted WL had more than 6 decimals, whereas the Rating Table (RT) was calibrated only to 2 decimals. Hence, initially WL values had to be refined to 2 decimals for use with RT values. Earlier a vlookup function which was posted in the forum was used, but it took a long time to process But when the findrows function was available, data processing was dramatically fast. Both Excel and SM files must be in the same folder. Cheers 1.July WL&RT.xlsx (30kb) downloaded 17 time(s). Find_Flows-R1.sm (27kb) downloaded 20 time(s). Find_Flows-R1.pdf (235kb) downloaded 30 time(s).Edited by user 07 March 2023 19:00:22(UTC)
