Offline soomoon
#1 Posted : 06 March 2023 11:02:40(UTC)
soomoon
Korea, Republic Of
I would like to have a function like lookup (vlookup, hlookup) in smath.
thank you.
thanks 1 user thanked soomoon for this useful post.
on 06/03/2023(UTC)
Offline joaobr
#2 Posted : 06 March 2023 11:45:04(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
findrows function within Special Functions plugin is what you're looking for, soomoon
#3 Posted : 06 March 2023 14:36:22(UTC)
Find Index Key Code is lot more powerful.
Assume your Customer wants more information from his bar diameter
you can give all pertaining informations ...
Add price column, material, delivery ... etc.
bar size Findndex KeyCode.sm (11kb) downloaded 36 time(s).
Offline ndtma
#4 Posted : 06 March 2023 15:14:07(UTC)
ndtma
Sri Lanka
Was thanked: 127 time(s) in 82 post(s)
bar size.sm (10kb) downloaded 20 time(s).
Edited by user 06 March 2023 15:23:05(UTC)  | Reason: Not specified
thanks 1 user thanked ndtma for this useful post.
on 06/03/2023(UTC)
Offline joaobr
#5 Posted : 06 March 2023 16:05:04(UTC)
joaobr
Brazil
Jean, your example shows EXACTLY what findrows does.
#6 Posted : 06 March 2023 23:23:05(UTC)
Yes for that simple application.
FindIdx(V,x,col) gives me more for advanced Engineering works
Thanks for the observation.
Offline overlord
#7 Posted : 07 March 2023 05:46:16(UTC)
Turkey
Was thanked: 511 time(s) in 341 post(s)
https://en.smath.com/forum/yaf_postst673_lookup.aspx
Check thread above. You may find it useful.
You can look forum for your questions by searching too.
Searching may result with a ready answer to a question.
Offline ndtma
#8 Posted : 07 March 2023 18:30:02(UTC)
ndtma
Sri Lanka
findrows() function revisited.
As a part of a project undertaken to study flows of some perennial streams in Sri Lanka,
a particular stream, located far away from Colombo, was selected and a Rating Table (RT) was
prepared relating water levels to flows. This process took a few years so that the
data would almost cover reasonable range of depths for practical reasons, excluding severe floods.
During this period, an electronic device was also constructed to measure water levels (WL) and
transmit as digital signals to control station in Colombo.
However, the numerical values of transmitted WL had more than 6 decimals,
whereas the Rating Table (RT) was calibrated only to 2 decimals. Hence, initially WL values
had to be refined to 2 decimals for use with RT values.
Earlier a vlookup function which was posted in the forum was used, but it took a long time to process
But when the findrows function was available, data processing was dramatically fast.
Both Excel and SM files must be in the same folder.
Cheers
1.July WL&RT.xlsx (30kb) downloaded 17 time(s).
Find_Flows-R1.sm (27kb) downloaded 20 time(s).
Find_Flows-R1.pdf (235kb) downloaded 30 time(s).
Edited by user 07 March 2023 19:00:22(UTC)  | Reason: Not specified
on 08/03/2023(UTC)
