Poll Question : Do you plan to use SMath Viewer
Choice Votes Statistics
  In learning
12
17 %
  For personal usage
26
37 %
  In buziness
30
42 %
  Useless for me
2
2 %
  Total 70 100%
Guests can't vote. Try login or register.
2 Pages<12
Offline CBG
#21 Posted : 13 June 2019 03:45:16(UTC)
CBG
Was thanked: 65 time(s) in 47 post(s)
Originally Posted by: G-Tate Go to Quoted Post
I found a way!
But it takes time depending on how many vectors you use.
I defined the single element indexes and gave them a name.
Hello G-Tate
I think it is better that you use Excel for data in the form of Vector or Matrix,
and then import them from SMathStudio, so that, the changes you make are saved in the Excel sheet
PruebaImport_Cost_English.zip (1,038kb) downloaded 23 time(s).
Carlos
Offline oscampo
#22 Posted : 13 June 2019 19:40:29(UTC)
oscampo
Colombia
Was thanked: 54 time(s) in 41 post(s)
Ok...but...
I think that the point is that in this way you neither can edit any value in the viewer...
Offline CBG
#23 Posted : 13 June 2019 20:49:47(UTC)
CBG
Hello Oscampo
Originally Posted by: oscampo Go to Quoted Post
Ok...but...
In SmathViewer you can change the values of the variables, but it does not save any value,
that is, it remains the original value that was put in the SmathStudio
worksheet. SmathViewer is not persistent.
The idea of using it together with a spreadsheet (Excel or Libre Office) is in the
case of vectors or matrices with data that must be updated, without the need to
change the source code. For example for unit prices, so you do not have to type them every time.
Since from my point of view, the executable program of SmathViewer will be used
by a person who does not have access to the source code and who probably
does not know how to program, or who do not want to make changes to it. Otherwise,
if you have access to run the program in the source code (SmathStudio), what
sense would you have to use Smath Viewer?
SmathViewer needs to improve some functions, such as handling vectors and matrices, making persistent changes, etc.
Carlos
Offline Armand1
#24 Posted : 15 March 2021 13:48:34(UTC)
Armand1
Poland
Originally Posted by: Andrey Ivashov Go to Quoted Post
Hello.
Unfortunately it is Windows 10 which does not allow SMath Studio to save *.exe files (partially generated on server side).
That is why *.exe.tmp was created successfully, but it disappears on renaming from *.exe.tmp to *.exe. Operating system (Windows 10 in my case) detects this and removes final file completely.
Functionality should still work OK on other OSs.
For now I do not know what to do with this behavior of the OS.
you can't generate full version exe file for a long time. I would like to be able to use them in the company. Until this bug is fixed, wouldn't it be possible to remove the "not for commercial use" text altogether?
#25 Posted : 15 March 2021 19:14:31(UTC)
Was thanked: 1203 time(s) in 794 post(s)
There's a statement made by Andrey recently here
Edited by user 15 March 2021 19:31:08(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#26 Posted : 09 April 2021 01:09:17(UTC)
Was thanked: 1883 time(s) in 639 post(s)
Full version is now working again using https://en.smath.com/for...7769--09-April-2021.aspx
#27 Posted : 29 May 2021 14:37:19(UTC)
It is now possible to Save input data using Save dialog. It is also possible to load saved data using Open toolbar item afterwards - all saved values will be restored.
To enable Save/Open functionality an appropriate checkbox must be set to true during Save to *.exe:
on 30/05/2021(UTC)
Similar Topics
Smath Viewer compilation problem (Bugs & Problems)
by hernansgz 12/05/2021 07:49:53(UTC)
SMath viewer icon (Feature Requests)
by Razonar 08/03/2021 14:29:02(UTC)
SMath Viewer - Input Matrix/Vector of Variable size (Questions)
by wb.c 05/03/2021 17:27:05(UTC)
SMath Viewer on Linux (Features announcements)
by UdoMeier 19/02/2020 23:02:26(UTC)
String in SMath Viewer (Questions)
by FeCO 14/03/2019 18:32:14(UTC)
Header / footer values displayed in SMath Viewer (Feature Requests)
by fedeghi 14/11/2018 11:56:54(UTC)
Resize SMath Viewer window (Questions)
by lcesero 10/09/2018 18:19:33(UTC)
Smath Viewer Output Window to display main output results (Feature Requests)
by fedeghi 24/07/2018 19:03:11(UTC)
How to display string element of the matrix in Smath Viewer? (Questions)
by barmin 29/06/2018 14:53:06(UTC)
[include plugin] missing LinqBridge.dll error in SMath Viewer executables (Bugs & Problems)
by resist 24/11/2017 18:07:37(UTC)
Smath Viewer - The choice of data entry (Project discussion)
by veb 13/07/2017 13:57:06(UTC)
Smath Viewer compiling (Questions)
by CBG 07/02/2017 02:48:18(UTC)
[SV-2373][PRO] can't open Smath Viewer files (Bugs & Problems)
by CBG 31/08/2016 18:58:56(UTC)
Smath Viewer EXE file password (Questions)
by CBG 31/08/2016 18:32:50(UTC)
Units filter for SMath Viewer (Feature Requests)
by brenyw 16/08/2016 03:51:45(UTC)
2 Pages<12
