SMath Studio Forum
Questions
How to enforcing simbolic evaluation?
Even if the variable have been defined. E.g. how to get x=(a+b)(a-b)even if a=1, b=2 Edited by user 20 February 2021 09:20:20(UTC)
| Reason: Not specified
Thanks, but I want to know how to get U=(a+b )*(a-b ), even if a=1, b=2 is on the top Edited by user 20 February 2021 16:29:23(UTC)
Originally Posted by: netsonicyxf Thanks, but I want to know how to get U=(a b )*(a-b ), even if a=1, b=2 is on the top I simply don't understand your request. Read Martin handbook, to learn using Smath.
I think the only way is to delete the defintions by using Clear(a; = .
Originally Posted by: MarB I think the only way is to delete the definitions by using Clear(a;= . No need, algo is self clearing.
Joined: 28/08/2014(UTC) Posts: 1,357 Was thanked: 817 time(s) in 517 post(s)
Hi. As MarB says, only with Clear(a , b ) in SMath. However, it is true that in Mathcad you can hide the numeric values for a symbolic evaluation: Best regards. Alvaro.
Originally Posted by: MarB I think the only way is to delete the defintions by using Clear(a; = . Originally Posted by: Razonar Hi. As MarB says, only with Clear(a , b ) in SMath. However, it is true that in Mathcad you can hide the numeric values for a symbolic evaluation:
really wish Smath can perform like MathCAD
Thanks Jean.
BTW, MathCAD doesn't need to do clearance.
Originally Posted by: netsonicyxf BTW, MathCAD doesn't need to do clearance. True for that little example. More advanced stuff needs be cleared as well. The symbolic arrow was demanded but not implemented.
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,650 Location: Italy Was thanked: 1338 time(s) in 878 post(s)
The only way is to define the variables after the expression, then you can show the expression using Clear. The other way doesn't works because when values are set before the expression, the values are stored in memory, not the variable names. |
Originally Posted by: netsonicyxf Thanks Jean.
BTW, MathCAD doesn't need to do clearance. Hi. It needs. That is the mean for a:=a and b:=b, which clear a and b only for symbolics, but not for numerics. If you want to show the symbilic value stored in x cleaning a and b after you define x, you can use line() in the definitions: Also notice that you need to eval Clear(a, b ) = 1, if not SMath not recognize that as an instruction. Best regards. Alvaro.
SMath Studio Forum
Questions
