Offline netsonicyxf
#1 Posted : 20 February 2021 09:17:40(UTC)
netsonicyxf
Even if the variable have been defined.
E.g. how to get x=(a+b)(a-b)even if a=1, b=2
Edited by user 20 February 2021 09:20:20(UTC)  | Reason: Not specified
#2 Posted : 20 February 2021 15:39:43(UTC)
Offline netsonicyxf
#3 Posted : 20 February 2021 16:20:42(UTC)
netsonicyxf
Thanks, but I want to know how to get U=(a+b )*(a-b ), even if a=1, b=2 is on the top
Edited by user 20 February 2021 16:29:23(UTC)  | Reason: Not specified
#4 Posted : 20 February 2021 18:01:23(UTC)
Originally Posted by: netsonicyxf Go to Quoted Post
Thanks, but I want to know how to get U=(a b )*(a-b ), even if a=1, b=2 is on the top
I simply don't understand your request.
Read Martin handbook, to learn using Smath.
Offline MarB
#5 Posted : 20 February 2021 19:02:11(UTC)
MarB
I think the only way is to delete the defintions by using Clear(a;Cool= .
#6 Posted : 20 February 2021 19:15:24(UTC)
Originally Posted by: MarB Go to Quoted Post
I think the only way is to delete the definitions by using Clear(a;= .
No need, algo is self clearing.
#7 Posted : 20 February 2021 23:18:06(UTC)
Offline Razonar
#8 Posted : 21 February 2021 07:25:56(UTC)
Razonar
Uruguay
Hi. As MarB says, only with Clear(a , b ) in SMath. However, it is true that in Mathcad you can hide the numeric values for a symbolic evaluation:
Offline netsonicyxf
#9 Posted : 21 February 2021 15:24:07(UTC)
netsonicyxf
really wish Smath can perform like MathCAD
#10 Posted : 21 February 2021 17:00:13(UTC)
Offline netsonicyxf
#11 Posted : 21 February 2021 17:10:37(UTC)
netsonicyxf
Thanks Jean.
BTW, MathCAD doesn't need to do clearance.
#12 Posted : 21 February 2021 18:00:32(UTC)
True for that little example. More advanced stuff needs be cleared as well.
The symbolic arrow was demanded but not implemented.
#13 Posted : 21 February 2021 19:27:04(UTC)
The only way is to define the variables after the expression, then you can show the expression using Clear. The other way doesn't works because when values are set before the expression, the values are stored in memory, not the variable names.
Offline Razonar
#14 Posted : 21 February 2021 19:28:15(UTC)
Razonar
Uruguay
Thanks Jean.
Hi. It needs. That is the mean for a:=a and b:=b, which clear a and b only for symbolics, but not for numerics. If you want to show the symbilic value stored in x cleaning a and b after you define x, you can use line() in the definitions:
Also notice that you need to eval Clear(a, b ) = 1, if not SMath not recognize that as an instruction.
on 22/02/2021(UTC)
