SMath Studio Forum
Questions
How to enforcing simbolic evaluation?
Even if the variable have been defined. E.g. how to get x=(a+b)(a-b)even if a=1, b=2   Edited by user 20 February 2021 09:20:20(UTC)
| Reason: Not specified
Joined: 04/07/2015(UTC) Posts: 5,255  Was thanked: 825 time(s) in 656 post(s)
Thanks, but I want to know how to get U=(a+b )*(a-b ), even if a=1, b=2 is on the top Edited by user 20 February 2021 16:29:23(UTC)
Originally Posted by: netsonicyxf  Thanks, but I want to know how to get U=(a b )*(a-b ), even if a=1, b=2 is on the top I simply don't understand your request. Read Martin handbook, to learn using Smath.
Was thanked: 13 time(s) in 13 post(s)
I think the only way is to delete the defintions by using Clear(a;  = .
Originally Posted by: MarB  I think the only way is to delete the definitions by using Clear(a;= . No need, algo is self clearing.
Joined: 28/08/2014(UTC) Posts: 687  Was thanked: 355 time(s) in 231 post(s)
Hi. As MarB says, only with Clear(a , b ) in SMath. However, it is true that in Mathcad you can hide the numeric values for a symbolic evaluation:  Best regards. Alvaro.
Originally Posted by: MarB  I think the only way is to delete the defintions by using Clear(a;  = .  Originally Posted by: Razonar  Hi. As MarB says, only with Clear(a , b ) in SMath. However, it is true that in Mathcad you can hide the numeric values for a symbolic evaluation:
really wish Smath can perform like MathCAD
Thanks Jean.
BTW, MathCAD doesn't need to do clearance.
Originally Posted by: netsonicyxf  BTW, MathCAD doesn't need to do clearance. True for that little example. More advanced stuff needs be cleared as well. The symbolic arrow was demanded but not implemented.
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,344   Location: Italy Was thanked: 1180 time(s) in 776 post(s)
The only way is to define the variables after the expression, then you can show the expression using Clear. The other way doesn't works because when values are set before the expression, the values are stored in memory, not the variable names. |
Originally Posted by: netsonicyxf  Thanks Jean.
BTW, MathCAD doesn't need to do clearance. Hi. It needs. That is the mean for a:=a and b:=b, which clear a and b only for symbolics, but not for numerics. If you want to show the symbilic value stored in x cleaning a and b after you define x, you can use line() in the definitions:  Also notice that you need to eval Clear(a, b ) = 1, if not SMath not recognize that as an instruction. Best regards. Alvaro.
SMath Studio Forum
Questions
