32 Pages«<1718192021>»
Offline veb
#361 Posted : 5 years ago
veb
Originally Posted by: uni Go to Quoted Post
Unfortunately, this cannot be done yet.
Is there any other extension for smath that allows this?
Offline uni
#362 Posted : 5 years ago
uni
Was thanked: 1400 time(s) in 817 post(s)
Yes, ZedGraph Region supports such axes.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
#363 Posted : 5 years ago
Originally Posted by: veb Go to Quoted Post
It is necessary to display a logarithmic graph, how to do it in smath?
Try X_Y Zgraph.
Project Bode plot.sm (28kb) downloaded 61 time(s).
2D Plot Stem log10 DECADES Bode.sm (169kb) downloaded 47 time(s).
Offline veb
#364 Posted : 5 years ago
veb
Uni and Jean Giraud thank you very much!!!
ZedGraph Region made a logarithmic coordinate axis and build everything
#365 Posted : 5 years ago
Such applications are very limited, for convenience.
IMHO, not much useful as we are born Cartesian sight.
Offline alyles
#366 Posted : 5 years ago
alyles
Was thanked: 93 time(s) in 58 post(s)
I disagree. In electronics engineering we often deal in frequency domain with such applications as filter design, EMI/EMC, control.. just to name a few. Being able to plot on logarithmic scale is necessary in such applications.
#367 Posted : 5 years ago
A great utility is the logpts for convenient tabulation/export.
Very useful to adequately populate the vertical region and not
over populate the flat region, especially for interpolation.
Utilities logpts Populate Quick.sm (15kb) downloaded 43 time(s).
Offline mkraska
#368 Posted : 5 years ago
mkraska
The maxima plugin allows for log plots (all functions of the draw package are available, the draw commands generate images which can be displayed using image region. Alternatively, there are interactive draw regions provided by the plugin.
See for example Ashby style material property charts
Offline Razonar
#369 Posted : 5 years ago
Razonar
Uruguay
Was thanked: 988 time(s) in 617 post(s)
The maxima plugin allows for log plots ...
Hi. Can try this other one also, in SMath lang.
examples MNA RLC.sm (220kb) downloaded 73 time(s).
examples MNA RLC.pdf (319kb) downloaded 63 time(s).
on 22/11/2019(UTC)
Offline veb
#370 Posted : 5 years ago
veb
wow !!!
When Uni told me that the X-U region does not support the logarithmic axis, I was upset and thought that I could do it in a standard tool. But I could not even imagine that it would be so difficult.
ZedGraf region perfectly copes with the task, it is possible to make legends (have not yet learned). We rarely use charts in calculations.
#371 Posted : 5 years ago
Disambiguate:
Smath does not have the Cartesian x,y log axis from command line
like Mathcad 11 and earlier. In lieu X_Y ZedGraph plugin.
I guess Uni [our Viacheslav] is same from former Mathsoft Collaboratory.
Offline oscampo
#372 Posted : 5 years ago
oscampo
Colombia
Was thanked: 124 time(s) in 83 post(s)
Hello!
Help with this extension.
I looked at the settings did not find such an opportunity.
Hi, maybe you can use the information of this post: https://en.smath.com/forum/yaf_postsm7005_Signals-and-Systems.aspx#post7005
thanks 1 user thanked oscampo for this useful post.
on 25/11/2019(UTC)
Offline veb
#373 Posted : 5 years ago
veb
Thanks, I'll keep it in mind.
But while the ZedGraph Region completely suits me.
#374 Posted : 5 years ago
What you can do in the linear Cartesian,
you can subdivide between integer values of the quick plot.
You can subdivide in any number of sub-intervals and log10
these sub-intervals. Then plot the stems at those intervals.
Utilities logpts SQRT X,Y.sm (29kb) downloaded 41 time(s).
Offline mkraska
#375 Posted : 5 years ago
mkraska
Pie chart with random colors
piechart.sm (10kb) downloaded 42 time(s).
thanks 4 users thanked mkraska for this useful post.
on 09/02/2020(UTC),  on 09/02/2020(UTC),  on 09/02/2020(UTC),  on 09/02/2020(UTC)
#376 Posted : 5 years ago
Thanks Martin, interesting but not Smath native.
Obviously fails SS 6179 and no use for concluding a document.
Offline uni
#377 Posted : 5 years ago
uni
Updated.
setprop() function changed for support ZedGraph region.
on 22/04/2020(UTC),  on 22/04/2020(UTC)
Offline joaobr
#378 Posted : 5 years ago
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Awesome!
I've just tested it and it fixes the Viewer issue I mentioned in another post.
Any chance it can access the configurations of indivual plots inside a ZedGraph Region? In other words, is it possible to address specific Traces?
Offline uni
#379 Posted : 5 years ago
uni
It is possible, but not yet implemented. Also for the ZedGraph region the new Name property is not saved yet.
Offline uni
#380 Posted : 5 years ago
uni
Updated.
Changes:
- trace quality improved;
- now default value for AntiAlias is true;
- Y2 grid lines added;
- setprop() function improved.
Theoretically, we can set the dash style for implicit functions as well, but this is more difficult to implement.
Edited by user 5 years ago  | Reason: Not specified
on 10/05/2020(UTC),  on 16/07/2020(UTC)
Guest (2)
Similar Topics
X-Y Plot Region Plugin (Extensions)
by ndtma 7 years ago
X-Y Plot Region Plugin Problem (Questions)
