2 Pages12>
#1 Posted : 03 May 2014 19:23:15(UTC)
Was thanked: 1318 time(s) in 869 post(s)
SMath Studio compatibility SMath Viewer compatibility mono compatibility
extension page Sources MIT license
  • installation: SMath Studio: Tools > Plugins... > Online Gallery;
  • documentation: see attachment or Activebook;
  • UI languages: English;
  • Main features:
    • Selection/Navigation: mouse click, return key, mouse wheel, + and - keys, goto by leading characters (text and math);
    • Settings: double-click over the selected item (in the header or in the drop-down list) / context menu item;
    • Input: any vector/matrix/system of any size;
    • Output: place a variable in the region placeholder;
    • Size driven by the values (manual resize not allowed);
    • Adds the same controls in SMath Viewer;
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabelNumericUpDown | PathPicker | RadioButtonList | Slider
Edited by user 01 November 2021 13:33:19(UTC)  | Reason: Links
File Attachment(s):
ComboBoxList - examples.sm (19kb) downloaded 784 time(s).
2014-05-04 21_05_55-SMath Studio Desktop - [ComboBoxList - examples.sm_].png
thanks 3 users thanked Davide Carpi for this useful post.
on 03/05/2014(UTC),  on 03/05/2014(UTC),  on 03/05/2014(UTC)
#2 Posted : 03 May 2014 19:58:47(UTC)
last-minute fix for "goto by leading characters" uploaded (typing characters on collapsed drop-down list now expands the list).
on 03/05/2014(UTC)
#3 Posted : 04 July 2014 13:36:54(UTC)
Originally Posted by: ioan92 Go to Quoted Post
It seems that the control width is not adapting to the control content width.
Thank you Ioan, confirmed (even if needs more investigation, because I can't reproduce it every time...). I'll fix it ASAP.
A small workaround to adjust the size and to avoid the freeze of the canvas is to minimize and then restore the Smath window.
Best regards,
Davide
on 04/07/2014(UTC)
#4 Posted : 04 July 2014 20:52:30(UTC)
Fixed (collateral effects of API changes, nothing serious)
RC: SMath Studio 0.97.5301
- Code updated to fit recent API changes;
- Fixed sizes calculation logic to allow clicks even when the region becomes wider;
- [DEV] Removed OnKeyPress global hook;
- Password option is no more available, so from now the plugin is marked as Beta.
Best regards,
Davide
Edited by user 07 July 2014 00:40:47(UTC)  | Reason: Not specified
on 04/07/2014(UTC)
Offline mkraska
#5 Posted : 06 August 2014 12:34:45(UTC)
mkraska
Was thanked: 1094 time(s) in 698 post(s)
As stated in this post, I do not experience the problems reported SMath 0.97.5329 download topic. The attached files all run without problems and I can access all controls without crash.
File Attachment(s):
Bedienelemente.sm (14kb) downloaded 287 time(s).
Plugin Slider Region.sm (16kb) downloaded 157 time(s).
on 06/08/2014(UTC)
#6 Posted : 06 August 2014 12:48:27(UTC)
Thank you Martin Good
I don't know where is the difference (on my machine the error shown in the previous screenshot was made yesterday on the desktiop distribution and today with your portable distribution - both with the second-last version of the plugin)
Just to have a complete debug, you can see the dynamic preview when you change the input variable from the ComboBoxList region? I have issues both with the last and the second-last plugins.
Thanks in advance,
Davide
Edited by user 06 August 2014 12:55:20(UTC)  | Reason: Not specified
Offline mkraska
#7 Posted : 06 August 2014 13:13:26(UTC)
mkraska
Thanks in advance,
Davide
The portable version seems to contain the version 0.97.5327 (release candidate), this is going to be corrected . But anyways, So far, I tried 0.97.5327 and 0.97.5329 with and without updated control regions and do not get a crash at all.
I am not sure what you mean by changing the input variable. Should I replace c by something else? The screenshots are with latest SMath and latest plugins.
on 06/08/2014(UTC)
#8 Posted : 06 August 2014 13:15:24(UTC)
I mean changing the value of the "Source" parameter in the form Good
Offline mkraska
#9 Posted : 06 August 2014 13:36:19(UTC)
mkraska
I defined another matrix d, switched the input to it and don't see any problem.
on 06/08/2014(UTC)
#10 Posted : 06 August 2014 14:56:46(UTC)
This is good, in one hand. Good
In the other hand, like Ioan, I have noticed issues on evaluations (trigggered twice, not triggered, triggered correctly...) both on the desktop and the portable distributions.
screencasts: evaluation triggered twice , evaluation not triggered
I have Win 7 x64 (home premium) and your same framework (2.0.50727.5477) but the behaviors is not the same (both on the desktop and the portable distributions). Wallbash
Edited by user 06 August 2014 15:20:09(UTC)  | Reason: Not specified
on 06/08/2014(UTC)
Offline mkraska
#11 Posted : 06 August 2014 16:12:01(UTC)
mkraska
* after recent Davide's plugins rebuilt in the context of the SMath 0.97.5329, I have no more execution crashes;
* in the new version, after each event (click or change) on a ComboBoxList, the recalculation of the file is triggered; append is a test file; is this behavior general or machine dependent ?
Observed behaviour for Ioan's file (no difference between old and new plugin version)
- I had no crashes
- I get a re-calculation only and reproducible
- when I change the value (e.g. using mouse wheel and then leave the region (mousewheel action alone does not trigger recalc)
- when I change the value by clicking.
This seems reasonable behaviour to me.
on 06/08/2014(UTC)
#12 Posted : 06 August 2014 17:14:26(UTC)
Well, maybe a day we will see a targeted recalculation (just on regions related with changed values) Good
on 06/08/2014(UTC)
Offline mkraska
#13 Posted : 06 August 2014 17:20:46(UTC)
mkraska
The only aspect that I do not agree in your evaluation is issued from the "axiom" that: the calculation of a page must start only:
* automatically, when this option is selected;
* by explicit user command from menu.
Other reasons (control click or control change events) to start of the calculations are not normals and are annoying Sad , especially when working with big files.
Ioan,
I agree, that the control regions should obey the setting of the automatic re-calculation toggle (I normally have this "on" ). And in fact, at least the radiobutton list region does not care about the setting, even though it has a display flag which reflects the current re-calculate setting in the upper right corner.
If auto recalc is on, then I prefer getting immediate action upon changed values, e.g. if the values drive some graphics, as in my slider example. I'd vote for keeping it this way.
The bug is then that the recalc setting is not obeyed (which I can reproduce). Fixing that should help with your problem.
on 06/08/2014(UTC)
#14 Posted : 07 August 2014 17:24:36(UTC)
Here there are different things...
1) Recalculations (evaluations) does not obey "Auto calculation" settings
-> this can be fixed by me with a little bit different design of the plugins, or by Andrey, with a different handling of RequestForEvaluation. Actually I have no ideas about what is the best way (except that I think that if I want to trigger an evaluation, this should be possible), but is not a problem for me to make the fix from the plugin side.
2) Exceptions on opening settings' form.
-> Martin does not experience this issue at all, I have this issues since SMath 0.97.5327 (tested with portable version made from linux package), and this is experienced also by Ioan. This was fixed recompiling the plugins, but the different behavior is really strange.
I've made a clean installation of SMath, used portable versions, used the .NET framework fix tool but nothing changes; I'm not sure if the broken verions are those where the errors are not shown or those where the errors are experienced. Crazy
3) Multiple recalculations (evaluation triggered twice)
-> Here seems (correct me if I'm wrong) that here are different behaviors on the machines. Martin does not experience this issue at all, Ioan every times with several plugins (see attachments and comments of SS-192), and me just sometimes (not in my test file but in the Ioan file just with this plugin).
4) No recalculation ( using ( ... CreateTransaction() ) not triggered)
-> This can be seen changing the data source of the region; if the region is updated without closing the form it works, otherwise is broken. This is not experienced at all by Martin, I experience this since SMath 0.97.5327 (again tested on portable version)
Wacko
P.S. the test on the 0.97.5327 was made just today, previously I have not made deep testings on that version
Edited by user 07 August 2014 17:47:41(UTC)  | Reason: Not specified
on 07/08/2014(UTC)
#15 Posted : 07 August 2014 20:03:22(UTC)
Wacko
Point 1 done by plugin design. No more evaluations if AutoRecalc is disabled.
I can do something also for the 4th point but requires more efforts (and will be just a workaround). Points 3 and behavior differences are in the fog, I don't understand where is the issue. Nea
Edited by user 07 August 2014 20:34:41(UTC)  | Reason: Not specified
Offline Andrey Ivashov
#16 Posted : 08 August 2014 02:15:01(UTC)
Was thanked: 1977 time(s) in 665 post(s)
Thank you! I will take a look at this issue.
on 08/08/2014(UTC),  on 08/08/2014(UTC)
#17 Posted : 08 August 2014 02:15:02(UTC)
on 08/08/2014(UTC)
#18 Posted : 13 February 2016 16:25:47(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and SMath Studio 0.97.5737
- Added Undo/Redo support;
- Plugins compiled for both the SS versions (no more crashes in SMath Studio 0.97.5346)
Offline ecki91
#19 Posted : 09 March 2016 02:28:39(UTC)
ecki91
hello guys!
dear Davide Carpi,
as I've been using your very util plugin during
my tesis for the calculation of wooden joints,
I found out about a problem concerning the combined
use along with the Viewer.
It seems to me the once the Viewer loaded the file, all
the settings about the input variables for the comboboxList
are made. In the case, like you see in the example-pictures,
of multiple lists depending on their selection to decide
about the next-ones input, it comes to dificulties concerning
the update process.
The problem still consists with the newest version of SMath.
Is there a way to fix this problem?
I'd be glad aboud any advice of solution!
Thanks a lot!
Greetings,
Eckhard Bräuchler
#20 Posted : 09 March 2016 13:57:22(UTC)
Confirmed, I'll provide a fix ASAP.
Edited by moderator 09 March 2016 15:17:27(UTC)  | Reason: I deleted the post Davide requested (omorr).
2 Pages12>
