  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,618   Location: Italy Was thanked: 1322 time(s) in 872 post(s)
- installation: SMath Studio: Tools > Plugins... > Online Gallery;
- documentation: see attachment or Activebook;
- UI languages:
- Main features:
- Selection/Navigation: mouse click, return key, mouse wheel, + and - keys, goto by leading characters (text and math);
- Settings: double-click over the selected item (in the header or in the drop-down list) / context menu item;
- Input: any vector/matrix/system of any size;
- Output: place a variable in the region placeholder;
- Size driven by the values (manual resize not allowed);
- Adds the same controls in SMath Viewer;
>>> PLEASE REPORT IN THIS TOPIC ANY ISSUE, MORE DETAILED AS POSSIBLE <<<
OLD docuentation:
Password: test
Control Regions: CheckBoxList | ComboBoxList | ConditionallyFormattedLabel | NumericUpDown | PathPicker | RadioButtonList | SliderEdited by user 01 November 2021 13:33:19(UTC)
| Reason: Links File Attachment(s): Davide Carpi attached the following image(s): |
 3 users thanked Davide Carpi for this useful post.
on 03/05/2014(UTC), on 03/05/2014(UTC), on 03/05/2014(UTC)
last-minute fix for "goto by leading characters" uploaded (typing characters on collapsed drop-down list now expands the list). |
Originally Posted by: ioan92  It seems that the control width is not adapting to the control content width. Thank you Ioan, confirmed (even if needs more investigation, because I can't reproduce it every time...). I'll fix it ASAP. A small workaround to adjust the size and to avoid the freeze of the canvas is to minimize and then restore the Smath window. Best regards, Davide |
Fixed (collateral effects of API changes, nothing serious) RC: SMath Studio 0.97.5301- Code updated to fit recent API changes; - Fixed sizes calculation logic to allow clicks even when the region becomes wider; - [DEV] Removed OnKeyPress global hook; - Password option is no more available, so from now the plugin is marked as Beta. Best regards, Davide Edited by user 07 July 2014 00:40:47(UTC)
Joined: 15/04/2012(UTC) Posts: 1,944  Was thanked: 1103 time(s) in 704 post(s)
As stated in this post, I do not experience the problems reported SMath 0.97.5329 download topic. The attached files all run without problems and I can access all controls without crash. File Attachment(s): mkraska attached the following image(s): |
Thank you Martin  I don't know where is the difference (on my machine the error shown in the previous screenshot was made yesterday on the desktiop distribution and today with your portable distribution - both with the second-last version of the plugin) Just to have a complete debug, you can see the dynamic preview when you change the input variable from the ComboBoxList region? I have issues both with the last and the second-last plugins. Thanks in advance, Davide Edited by user 06 August 2014 12:55:20(UTC)
Originally Posted by: w3b5urf3r_reloaded  Thank you Martin  I don't know where is the difference (on my machine the error shown in the previous screenshot was made yesterday on the desktiop distribution and today with your portable distribution - both with the second-last version of the plugin) Just to have a complete debug, you can see the dynamic preview when you change the input variable from the ComboBoxList region? I have issues both with the last and the second-last plugins. Thanks in advance, Davide The portable version seems to contain the version 0.97.5327 (release candidate), this is going to be corrected . But anyways, So far, I tried 0.97.5327 and 0.97.5329 with and without updated control regions and do not get a crash at all. I am not sure what you mean by changing the input variable. Should I replace c by something else? The screenshots are with latest SMath and latest plugins. mkraska attached the following image(s): |
I mean changing the value of the "Source" parameter in the form Davide Carpi attached the following image(s): |
I defined another matrix d, switched the input to it and don't see any problem. mkraska attached the following image(s): |
Originally Posted by: mkraska  I defined another matrix d, switched the input to it and don't see any problem. This is good, in one hand.  In the other hand, like Ioan, I have noticed issues on evaluations (trigggered twice, not triggered, triggered correctly...) both on the desktop and the portable distributions. screencasts: evaluation triggered twice , evaluation not triggeredI have Win 7 x64 (home premium) and your same framework (2.0.50727.5477) but the behaviors is not the same (both on the desktop and the portable distributions).  Edited by user 06 August 2014 15:20:09(UTC)
Originally Posted by: ioan92  * after recent Davide's plugins rebuilt in the context of the SMath 0.97.5329, I have no more execution crashes; * in the new version, after each event (click or change) on a ComboBoxList, the recalculation of the file is triggered; append is a test file; is this behavior general or machine dependent ?
Observed behaviour for Ioan's file (no difference between old and new plugin version) - I had no crashes - I get a re-calculation only and reproducible - when I change the value (e.g. using mouse wheel and then leave the region (mousewheel action alone does not trigger recalc) - when I change the value by clicking. This seems reasonable behaviour to me. |
Well, maybe a day we will see a targeted recalculation (just on regions related with changed values) |
Originally Posted by: ioan92  The only aspect that I do not agree in your evaluation is issued from the "axiom" that: the calculation of a page must start only: * automatically, when this option is selected; * by explicit user command from menu.
Other reasons (control click or control change events) to start of the calculations are not normals and are annoying  , especially when working with big files. Ioan, I agree, that the control regions should obey the setting of the automatic re-calculation toggle (I normally have this "on" ). And in fact, at least the radiobutton list region does not care about the setting, even though it has a display flag which reflects the current re-calculate setting in the upper right corner. If auto recalc is on, then I prefer getting immediate action upon changed values, e.g. if the values drive some graphics, as in my slider example. I'd vote for keeping it this way. The bug is then that the recalc setting is not obeyed (which I can reproduce). Fixing that should help with your problem. |
Here there are different things... 1) Recalculations (evaluations) does not obey "Auto calculation" settings-> this can be fixed by me with a little bit different design of the plugins, or by Andrey, with a different handling of RequestForEvaluation. Actually I have no ideas about what is the best way (except that I think that if I want to trigger an evaluation, this should be possible), but is not a problem for me to make the fix from the plugin side. 2) Exceptions on opening settings' form.-> Martin does not experience this issue at all, I have this issues since SMath 0.97.5327 (tested with portable version made from linux package), and this is experienced also by Ioan. This was fixed recompiling the plugins, but the different behavior is really strange. I've made a clean installation of SMath, used portable versions, used the .NET framework fix tool but nothing changes; I'm not sure if the broken verions are those where the errors are not shown or those where the errors are experienced. 3) Multiple recalculations (evaluation triggered twice)-> Here seems (correct me if I'm wrong) that here are different behaviors on the machines. Martin does not experience this issue at all, Ioan every times with several plugins (see attachments and comments of SS-192), and me just sometimes (not in my test file but in the Ioan file just with this plugin). 4) No recalculation ( using ( ... CreateTransaction() ) not triggered)-> This can be seen changing the data source of the region; if the region is updated without closing the form it works, otherwise is broken. This is not experienced at all by Martin, I experience this since SMath 0.97.5327 (again tested on portable version) P.S. the test on the 0.97.5327 was made just today, previously I have not made deep testings on that versionEdited by user 07 August 2014 17:47:41(UTC)
Originally Posted by: w3b5urf3r_reloaded  Here there are different things... 1) Recalculations (evaluations) does not obey "Auto calculation" settings-> this can be fixed by me with a little bit different design of the plugins, or by Andrey, with a different handling of RequestForEvaluation. Actually I have no ideas about what is the best way (except that I think that if I want to trigger an evaluation, this should be possible), but is not a problem for me to make the fix from the plugin side. 2) Exceptions on opening settings' form.-> Martin does not experience this issue at all, I have this issues since SMath 0.97.5327 (tested with portable version made from linux package), and this is experienced also by Ioan. This was fixed recompiling the plugins, but the different behavior is really strange. I've made a clean installation of SMath, used portable versions, used the .NET framework fix tool but nothing changes; I'm not sure if the broken verions are those where the errors are not shown or those where the errors are experienced. 3) Multiple recalculations (evaluation triggered twice)-> Here seems (correct me if I'm wrong) that here are different behaviors on the machines. Martin does not experience this issue at all, Ioan every times with several plugins (see attachments and comments of SS-192), and me just sometimes (not in my test file but in the Ioan file just with this plugin). 4) No recalculation ( using ( ... CreateTransaction() ) not triggered)-> This can be seen changing the data source of the region; if the region is updated without closing the form it works, otherwise is broken. This is not experienced at all by Martin, I experience this since SMath 0.97.5327 (again tested on portable version) P.S. the test on the 0.97.5327 was made just today, previously I have not made deep testings on that version Point 1 done by plugin design. No more evaluations if AutoRecalc is disabled. I can do something also for the 4th point but requires more efforts (and will be just a workaround). Points 3 and behavior differences are in the fog, I don't understand where is the issue.  Edited by user 07 August 2014 20:34:41(UTC)
  Rank: Administration Groups: Developers, Registered, Knovel Developers, Administrators, Advanced Member Joined: 11/07/2008(UTC) Posts: 1,614   Was thanked: 1977 time(s) in 665 post(s)
Thank you! I will take a look at this issue.
on 08/08/2014(UTC), on 08/08/2014(UTC)
PLUGIN UPDATED SMath Studio 0.97.5346 and SMath Studio 0.97.5737
- Added Undo/Redo support; - Plugins compiled for both the SS versions (no more crashes in SMath Studio 0.97.5346) |
hello guys! dear Davide Carpi, as I've been using your very util plugin during my tesis for the calculation of wooden joints, I found out about a problem concerning the combined use along with the Viewer. It seems to me the once the Viewer loaded the file, all the settings about the input variables for the comboboxList are made. In the case, like you see in the example-pictures, of multiple lists depending on their selection to decide about the next-ones input, it comes to dificulties concerning the update process. The problem still consists with the newest version of SMath. Is there a way to fix this problem? I'd be glad aboud any advice of solution! Thanks a lot! Greetings, Eckhard Bräuchler
Confirmed, I'll provide a fix ASAP. Edited by moderator 09 March 2016 15:17:27(UTC)
| Reason: I deleted the post Davide requested (omorr). |
