Offline ndtma
#1 Posted : 27 August 2023 11:58:19(UTC)
ndtma
Sri Lanka
Was thanked: 128 time(s) in 82 post(s)
Hello !
I have this display problem when trying to pass
a matrix to a Table.
Table_Region_Problem.sm (12kb) downloaded 17 time(s).
Edited by user 27 August 2023 12:32:01(UTC)  | Reason: Not specified
Offline overlord
#2 Posted : 27 August 2023 15:11:12(UTC)
Turkey
Was thanked: 545 time(s) in 367 post(s)
Unit summary doesn't work as it should either.
Maybe these are bugs. Regards
on 27/08/2023(UTC)
Offline ndtma
#3 Posted : 27 August 2023 21:07:33(UTC)
ndtma
Sri Lanka
Hello !
My post #1 is a simple example to show the Table Region problem.
The actual problem is related to a Slope Stability Analysis example,
where the result consist of the following.
1. Strip width
2. Relevant Min Factor of Safety (Min_FS)
3. Center cordinates (x,y) of slip circle relevant to Min_FS
4. Corresponding Radius of slip circle.
Offline mkraska
#4 Posted : 28 August 2023 10:31:21(UTC)
mkraska
In the attached sheet I tried to automatically compile a results summary. Note that there is a single entry point for unit specification in the algorithm (no chance for mismatch between displayed unit and unit used to calculate the numerical values.
1-3.sm (138kb) downloaded 27 time(s).
#5 Posted : 28 August 2023 13:53:00(UTC)
At post #3 construct the matrix as independent cols, thus compatible Table.
Next, nest the two pertinent cols to explicit your Engineering c/w header.
Offline Leonardo J. Cocco
#6 Posted : 05 January 2024 03:52:24(UTC)
Leonardo J. Cocco
Argentina
When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards,
Leonardo.
#7 Posted : 05 January 2024 04:04:34(UTC)
Leonardo.
Smath Solver 30405 is OK for my Tables.
#8 Posted : 05 January 2024 07:10:03(UTC)
Was thanked: 1396 time(s) in 910 post(s)
Leonardo.
New program versions might require to update code of some plugins. The release time it depends on how many plugins are affected and how many changes are required (also the Release Manager seems still not completely restored).
Edited by user 05 January 2024 07:13:07(UTC)  | Reason: Not specified
#9 Posted : 06 January 2024 00:10:22(UTC)
Plugin released, thanks to Andrey for updating the code.
#10 Posted : 09 January 2024 01:32:17(UTC)
Leonardo J. Cocco
Argentina
Thanks for your replies, they were of help.
