Joined: 05/06/2014(UTC) Posts: 351   Location: Colombo Was thanked: 130 time(s) in 84 post(s)
Hello ! I have this display problem when trying to pass a matrix to a Table. Table_Region_Problem.sm (12kb) downloaded 17 time(s). Edited by user 27 August 2023 12:32:01(UTC)
Joined: 23/07/2013(UTC) Posts: 1,198  Was thanked: 548 time(s) in 368 post(s)
Unit summary doesn't work as it should either. Maybe these are bugs. Regards
Hello ! My post #1 is a simple example to show the Table Region problem. The actual problem is related to a Slope Stability Analysis example, where the result consist of the following. 1. Strip width 2. Relevant Min Factor of Safety (Min_FS) 3. Center cordinates (x,y) of slip circle relevant to Min_FS 4. Corresponding Radius of slip circle.  |
Joined: 15/04/2012(UTC) Posts: 2,048  Was thanked: 1177 time(s) in 752 post(s)
In the attached sheet I tried to automatically compile a results summary. Note that there is a single entry point for unit specification in the algorithm (no chance for mismatch between displayed unit and unit used to calculate the numerical values. 1-3.sm (138kb) downloaded 27 time(s).![2023-08-28 09_20_14-SMath Solver - [1-3.sm_].png](/forum/resource.ashx?a=47918&b=2) |
Joined: 04/07/2015(UTC) Posts: 6,866  Was thanked: 983 time(s) in 811 post(s)
Originally Posted by: ndtma  My post #1 is a simple example to show the Table Region problem. At post #3 construct the matrix as independent cols, thus compatible Table. Next, nest the two pertinent cols to explicit your Engineering c/w header.
When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards, Leonardo.
Originally Posted by: Leonardo J. Cocco  When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards, Leonardo. Smath Solver 30405 is OK for my Tables. Jean
  Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,736   Location: Italy Was thanked: 1405 time(s) in 914 post(s)
New program versions might require to update code of some plugins. The release time it depends on how many plugins are affected and how many changes are required (also the Release Manager seems still not completely restored). Edited by user 05 January 2024 07:13:07(UTC)
Plugin released, thanks to Andrey for updating the code. |
Thanks for your replies, they were of help.
