Joined: 05/06/2014(UTC) Posts: 349 Location: Colombo Was thanked: 127 time(s) in 82 post(s)
Joined: 23/07/2013(UTC) Posts: 1,187 Was thanked: 541 time(s) in 364 post(s)
Unit summary doesn't work as it should either. Maybe these are bugs. Regards
Hello ! My post #1 is a simple example to show the Table Region problem. The actual problem is related to a Slope Stability Analysis example, where the result consist of the following. 1. Strip width 2. Relevant Min Factor of Safety (Min_FS) 3. Center cordinates (x,y) of slip circle relevant to Min_FS 4. Corresponding Radius of slip circle. |
Joined: 15/04/2012(UTC) Posts: 2,045 Was thanked: 1176 time(s) in 752 post(s)
In the attached sheet I tried to automatically compile a results summary. Note that there is a single entry point for unit specification in the algorithm (no chance for mismatch between displayed unit and unit used to calculate the numerical values. 1-3.sm (138kb) downloaded 27 time(s). |
Joined: 04/07/2015(UTC) Posts: 6,866 Was thanked: 983 time(s) in 811 post(s)
Originally Posted by: ndtma My post #1 is a simple example to show the Table Region problem. At post #3 construct the matrix as independent cols, thus compatible Table. Next, nest the two pertinent cols to explicit your Engineering c/w header.
When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards, Leonardo.
Originally Posted by: Leonardo J. Cocco When I downloaded the latest version of Smath Studio, the Table region Plugin does not updated correctly. As a consequence the files containing tables developed with the plugin do not open correctly. Is there any solution in the future for this issue?. Best regards, Leonardo. Smath Solver 30405 is OK for my Tables. Jean
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,722 Location: Italy Was thanked: 1385 time(s) in 906 post(s)
New program versions might require to update code of some plugins. The release time it depends on how many plugins are affected and how many changes are required (also the Release Manager seems still not completely restored). Edited by user about a year ago
Plugin released, thanks to Andrey for updating the code. |
Thanks for your replies, they were of help.
