3 Pages<123
Offline uni
#41 Posted : 22 April 2014 08:40:05(UTC)
uni
Was thanked: 1275 time(s) in 746 post(s)
Updated. Check SS-97: Maxima Draw: Update of png images fails now (Kay, Davide thanks). Hope this helps.
Russia ☭ forever
Viacheslav N. Mezentsev
on 22/04/2014(UTC)
Offline mkraska
#42 Posted : 22 April 2014 14:47:27(UTC)
mkraska
Thanks a lot, uni.
The file locking problem is solved.
Still there is a timing problem now. If it takes too long for Maxima to produce the image, then the image region does not find it or uses an existing old version.
For complex images, this renders the temporary image storage in the Maxima plugin dir useless, because the name is changed everytime the image is written.
In the attached example, you can try that.
If the name parameter is set to "mpc" (anything without name extension produces svg output) or "mpc.png", then a png- or svg file is created (as can be seen in the file manager). However, it is not displayed unless the sheet is re-calculated. If recalculation is triggered by selecting materials in the (now correctly storing settings) checkboxlist region, then the old image is displayed.
If the name argument is completely removed, then temporary names are used and nothing is displayed at all.
I see two ways to avoid this problem:
a) Maxima has to wait until the image file is written and only then return control to SMath (sounds like a slow down)
b ) The image region has to check on a regular basis if the file has changed. I don't know if that is possible.
EDIT: filed as issue SS-124
Edited by user 22 April 2014 15:27:44(UTC)  | Reason: Not specified
File Attachment(s):
Werkstoffdiagramme png.zip (51kb) downloaded 44 time(s).
Offline mkraska
#43 Posted : 04 August 2014 01:53:59(UTC)
mkraska
Plugin updated.
Changes:
- SS-179 border on/off now saved correctly
- SS-161 loss of edited image contents avoided by more careful temp dir cleanup.
Similar Topics
Image Region [size/scroll] (Samples)
by Jean Giraud 09/06/2023 16:43:22(UTC)
Image Region Plugin - unable to install in SS 7813 (Bugs & Problems)
by ndtma 25/05/2021 20:17:53(UTC)
IMAGE REGION DOESN´T WORK (Bugs & Problems)
by Leandro Martins 10/04/2021 02:22:13(UTC)
[Image Region] Not woring on Windows 10 Laptop (Bugs & Problems)
by shiju 28/04/2017 22:08:04(UTC)
Image Region Does Not Reset (Bugs & Problems)
by Jean Giraud 18/04/2017 17:34:04(UTC)
[Image Region] 6179 SMath.Studio Errors & Glitches (Bugs & Problems)
by Novice 31/01/2017 16:59:12(UTC)
Editable Image Region - Plugin Update (Extensions)
by Alex M. 14/02/2016 09:46:23(UTC)
Editable Image Region (Extensions)
by mkraska 03/05/2014 13:47:12(UTC)
3 Pages<123
