SMath Studio Forum
Bugs & Problems
[Image Region] Not woring on Windows 10 Laptop
Joined: 15/06/2014(UTC) Posts: 7 Location: Tamilnadu Was thanked: 1 time(s) in 1 post(s)
Smath is not properly working on my new windows 10 laptop. While loading the Smath program, the loading image suddenly goes smaller and then open the program. But the side panel is not visible, and the work space height is loaded in smaller than the screen height. When clicking the restore button near the close button at top corner, the side panel appears back. The screen response to the mouse and the keys are slow. Defining a variable is looking like not responding the program.
Can anybody help me....
Shiju
please check if you have the image region plugin installed and in this case remove it |
Thanks Carpi, It works now. Bye the bye, why is it so? Shiju Edited by moderator 02 October 2017 21:32:53(UTC)
| Reason: Not specified
Good it's currently under investigation, but since I'm not able to reproduce on my Win10 it's a little bit tricky to find the cause... Edited by user 16 November 2017 21:31:20(UTC)
| Reason: fixed |
Originally Posted by: shiju Thanks Carpi, It works now. Bye the bye, why is it so?
Shiju Hi Shiju! How did you fix it? I have the same problem on my laptop which it's running Windows 10. I don't know if it has to do with any display setting or with the Windows version. I was getting started with Smath two months ago but I had to stop the learning process a few days after starting. Now, I'm beginning again and I face the same problem. I would really appreciate any help on this topic. P.S. Excuse me for my English, it is not very good
Hi I removed the image region plugin. Then Smath is working fine now. Try this. Regards Shiju
Hi Shiju!
Thanks!! I removed the image region plugin and it's working now.
SMath Studio Forum
Bugs & Problems
