SMath Studio - SMath
SMath Studio is an excellent free tool that can be used by anyone ranging from students to professionals. I have used it since back in college, and it has been an invaluable tool for speeding up my productivity and design quality both in my work and hobby life.
Thank you Andrey!
more...
by William
Smath is easy to use tool and its is freeware.I used for engineering calculations instead of easing excel. Its a time saver.
more...
by Naresh varikuntla
I needed the simplest functions, which I did in Mathcad. Now this software does everything I need. Keep up the good work. Brilliant. Thank you.
more...
by Kunt Celebi
Edited by user 19 September 2019 19:22:38(UTC)
| Reason: Not specified
7 users thanked Andrey Ivashov for this useful post.
on 18/09/2019(UTC), on 18/09/2019(UTC), on 18/09/2019(UTC), on 18/09/2019(UTC), on 19/09/2019(UTC), on 19/09/2019(UTC), on 19/09/2019(UTC)
Thanks Andrey for cuddling our so cherished Smath. By same token, does it run correctly the Fission project ? It failed previous SS 7109. Cheers ... Jean Project Fission.sm (167kb) downloaded 39 time(s).
It seems that this new version of Smath Studio has several problems, for example sometimes it omits showing the description of the variable. In the Tables, it does not respect the settings given in any previous version. For now it is all that I have found, and I wonder, why in each new version, one thing is fixed and another is upset? Thank you. Best Regards Carlos
Originally Posted by: CBG For now it is all that I have found, and I wonder, why in each new version, one thing is fixed and another is upset? My suggestion is augment/enhance SS 6179. 1. Clean arithmetic palette from [1,2,3,4,5,6,7,8,9,0 ... +,-,*,/ =] 2. Replace Gamma(x) by Alvaro 15 D accuracy. 3. Add Carlos integrator algorithm. 4. Design a Clear(,) that evaporates previous use. 5. Maths in text region is baby classroom ... Mathsoft demonstrated, only Jean used it few times. 6. Some Mathcad documents ORIGIN 0 can't be converted ORIGIN 1, thus exclude Smath as well. ... few more Cheers ... Jean BTW Carlos: Fission is OK or red like 7109 ?
Joined: 05/06/2014(UTC) Posts: 348 Location: Colombo Was thanked: 125 time(s) in 82 post(s)
I too observe the Problem with Tables in 7200. Additionally, Maple tools also failed. |
Originally Posted by: CBG It seems that this new version of Smath Studio has several problems, for example sometimes it omits showing the description of the variable. Thank you! Fixed here: https://en.smath.com/for...--19-September-2019.aspxOriginally Posted by: CBG In the Tables, it does not respect the settings given in any previous version. For now it is all that I have found I will check Table Region today. Originally Posted by: CBG and I wonder, why in each new version, one thing is fixed and another is upset? It is because complexity of the program is very big and I have no testers except myself. I just can't test everything before every single release. That is why I introduced beta versions, so we can catch all problems before stable release. Best regards.
Originally Posted by: Andrey Ivashov Hello Andrey, This problem was fixed in the recent version (7201). Thank you. this problem triggered another one regarding the small numbers. I am still quite puzzled with this. Especially when you are trying different optimizations??? Best Regards, Radovan |
Originally Posted by: omorr this problem triggered another one regarding the small numbers. I am still quite puzzled with this. Especially when you are trying different optimizations??? Best Regards, Radovan This was fixed today. New version will be available in several hours. Best regards.
Originally Posted by: Andrey Ivashov I will check Table Region today. I've checked TableRegion and see that it uses <regions> tag to store data which is restricted as SMath Studio uses this tag for its own purposes. I've implemented a workaround to the logic of opening files to allow TableRegion work with <regions> tag but I can't guarantee that this workaround will continue working in future releases. So, it is pretty important to switch plug-in to use another tag name for its purposes. Best regards.
Hello Jean Fision is Ok also in 7202 Best Regards Carlos
Originally Posted by: Andrey Ivashov Originally Posted by: Andrey Ivashov I will check Table Region today. I've checked TableRegion and see that it uses <regions> tag to store data which is restricted as SMath Studio uses this tag for its own purposes. I've implemented a workaround to the logic of opening files to allow TableRegion work with <regions> tag but I can't guarantee that this workaround will continue working in future releases. So, it is pretty important to switch plug-in to use another tag name for its purposes. Best regards. Hello Andrey Thank you very much, now, the function Show description and Table, work very well in version 7202 Best Regards Carlos
1 user thanked CBG for this useful post.
