Offline Andrey Ivashov
#1 Posted : 18 September 2019 09:00:04(UTC)
Was thanked: 2012 time(s) in 680 post(s)
SMath Studio - SMath
Created by SMath LLC in the scope of SMath project. Published by smath.
  • SMath Studio box
  • Calculation of Gravitation Acceleration example
  • Example of animation on the Worksheet
  • Extensions Manager tool
  • Opened math Reference Book
  • SMath Viewer output to Autocad example
  • SMath Studio on iOS
  • SMath Studio on iPad
They trust us *
* Customers' names and logos are used with the written permission of the copyright holders.
They talk about us (all reviews...)
  • Great program for conducting engineering calculations. The ability to insert text blocks and pictures makes it perfect for both computation and communication of the results to colleagues.
    by Filip Finodeyev
  • As a student engineer, this is an amazing program to use for future engineers.
    by Erich Vajda
  • As a Civil Engineering professor, I've realized to be hard to find a software suitable for both introductory and advanced subjects. SMath is the only free software I know to get the job done. Try it out.
    by João Felipe Melo
  • Great little tool, happy that someone made this - best alternative for prime. I still hate the breakdown of the Mathcad legacy - you are a proud successor....
    by Robbert
  • Mi programa favorito para calculos matematicos en general
    by Joan Enric Coca
  • I needed the simplest functions, which I did in Mathcad. Now this software does everything I need. Keep up the good work. Brilliant. Thank you.
    by Kunt Celebi
  • Es un imprescindible para el día a día. Muchísimas gracias Mr Andrey Ivashov.
    by Ángel Álvarez
  • Alternativa gratuita fantastica a MathCAD ! This is a fantastic free alternative to Mathcad, strongly recommended to anyone dealing with engineering and calculus.
    by Marco
  • Buenísima aplicación.
    by Nicolás Troncoso
  • Great work of A. Ivashov. SMath Studio is a powerfull and extremely intuitive software. Suitable for daily engineering practice.
    by Eng. Carli (Italy)
SMath Studio in publications (all publications...)
SMath Studio plug-ins (all plug-ins...)
The functionality of the program can be expanded through the installation of plug-ins created by third-party developers and companies, as well as those prepared by the SMath LLC team. Most plug-ins are open source and can be modified if necessary.
  • Extends SMath Studio with a 3D Plot Region.
    Jack Xu, Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with more save/import/export features.
    Davide Carpi (davide.carpi@gmail.com)
  • Access to a set of programs for calculating properties of water, steam, gases and gases mixtures. Requires separate installation of the Water Steam Pro libraries and appropriate license for it (see http://www.wsp.ru/).
    ООО "ЭсМат"
  • Provides access to the free and open source computer algebra system Maxima.
    Kay Graubmann & Martin Kraska (THB www.th-brandenburg.de)
  • Extends SMath Studio with a X-Y Plot Region.
  • A SMath Studio native wrapper of the CoolProp library (www.coolprop.org) - thermophysical property database and wrappers for a selection of programming environments.
    Mike Kaganski
  • Contains nonlinear solvers for equations and systems of equations: Bisected Direct Quadratic Regula Falsi (BDQRF), Bisection, Brent's, Broyden's, Homotopy, Newton-Raphson, Ridder's, Secant, etc.
  • Digital Signal Processing Library: spectral analysis, IIR and FIR filters, resampling algorithms, etc.
    Sergey Bakhurin (http://dsplib.org), Viacheslav N. Mezentsev (viacheslavmezentsev@ya.ru)
  • Extends SMath Studio with statistical tools: Sample Estimators, Probability Density, Cumulative Density, Quantile functions, Random Numbers, etc.
  • Provides an interface to the SQLite relational database engine.
    Chris Bietz, Viacheslav N. Mezentsev
Edited by user 19 September 2019 19:22:38(UTC)  | Reason: Not specified
thanks 7 users thanked Andrey Ivashov for this useful post.
on 18/09/2019(UTC),  on 18/09/2019(UTC),  on 18/09/2019(UTC),  on 18/09/2019(UTC),  on 19/09/2019(UTC),  on 19/09/2019(UTC),  on 19/09/2019(UTC)
#2 Posted : 18 September 2019 15:44:32(UTC)
Thanks Andrey for cuddling our so cherished Smath.
By same token, does it run correctly the Fission project ?
It failed previous SS 7109.
Project Fission.sm (167kb) downloaded 40 time(s).
on 19/09/2019(UTC)
Offline CBG
#3 Posted : 19 September 2019 00:50:09(UTC)
CBG
It seems that this new version of Smath Studio has several problems, for example sometimes
it omits showing the description of the variable.
In the Tables, it does not respect the settings given in any previous version.
For now it is all that I have found, and I wonder, why in each new version, one thing is fixed and another is upset?
Thank you.
Carlos
#4 Posted : 19 September 2019 03:50:59(UTC)
My suggestion is augment/enhance SS 6179.
1. Clean arithmetic palette from [1,2,3,4,5,6,7,8,9,0 ... +,-,*,/ =]
2. Replace Gamma(x) by Alvaro 15 D accuracy.
3. Add Carlos integrator algorithm.
4. Design a Clear(,) that evaporates previous use.
5. Maths in text region is baby classroom ...
Mathsoft demonstrated, only Jean used it few times.
6. Some Mathcad documents ORIGIN 0 can't be converted ORIGIN 1,
thus exclude Smath as well.
... few more
BTW Carlos: Fission is OK or red like 7109 ?
Offline ndtma
#5 Posted : 19 September 2019 06:21:38(UTC)
ndtma
Sri Lanka
Was thanked: 130 time(s) in 84 post(s)
I too observe the Problem with Tables in 7200.
Additionally, Maple tools also failed.
#6 Posted : 19 September 2019 10:01:57(UTC)
Thank you! Fixed here: https://en.smath.com/for...--19-September-2019.aspx
#7 Posted : 19 September 2019 10:04:58(UTC)
I will check Table Region today.
It is because complexity of the program is very big and I have no testers except myself. I just can't test everything before every single release. That is why I introduced beta versions, so we can catch all problems before stable release.
Offline omorr
#8 Posted : 19 September 2019 16:52:44(UTC)
omorr
Serbia
Was thanked: 319 time(s) in 268 post(s)
Hello Andrey,
This problem was fixed in the recent version (7201). Thank you.
this problem triggered another one regarding the small numbers.
I am still quite puzzled with this. Especially when you are trying different optimizations???
Best Regards,
#9 Posted : 19 September 2019 19:15:57(UTC)
Best Regards,
This was fixed today. New version will be available in several hours.
#10 Posted : 19 September 2019 19:21:11(UTC)
I've checked TableRegion and see that it uses <regions> tag to store data which is restricted as SMath Studio uses this tag for its own purposes. I've implemented a workaround to the logic of opening files to allow TableRegion work with <regions> tag but I can't guarantee that this workaround will continue working in future releases. So, it is pretty important to switch plug-in to use another tag name for its purposes.
on 20/09/2019(UTC)
Offline CBG
#11 Posted : 20 September 2019 02:07:49(UTC)
CBG
Hello Jean
Fision is Ok also in 7202
Carlos
Offline CBG
#12 Posted : 20 September 2019 02:13:01(UTC)
CBG
Hello Andrey
Thank you very much, now, the function Show description and Table, work very well in version 7202
Carlos
thanks 1 user thanked CBG for this useful post.
on 20/09/2019(UTC)
