Nightly build: SMath Studio 0.96.4902 available Important notes - Remove all third-party plug-ins from "plugins" folder of previous installed SMath Studio before installing SMath Studio 0.96.4902;
- Instructions regarding how to publish your Examples/Plugins/Applications/Snippets to make them available within Extensions Manager will be added a bit later.
- Extensions Manager implemented;
- Insert Matrix dialog improved to select input values on focus;
- MSI installer improved to support different DPI settings;
- Added full support for assemblies implements more then one plugin;
- Execution script added to Mono Package;
- Added ability to export files to supported formats using command prompt;
- Fixed critical issue appears on context menu open for Region based on RegionHolder with hidden input data;
- Dependencies handling improved for sm/smz files;
- SMath Viewer repaired to correctly support plug-ins which contains several files;
- Semicolon symbol prohibited to be used as a part of variable/function name;
- Refactoring.
Download Edited by user 03 June 2013 03:30:08(UTC)
| Reason: Not specified
4 users thanked Andrey Ivashov for this useful post.
on 03/06/2013(UTC), on 03/06/2013(UTC), on 03/06/2013(UTC), on 05/06/2013(UTC)
Thank you Andrey Just started Smath in Linux using Mono execution script. It seems that closing newly introduced Extension Manager will close SMath to. Regards, Radovan |
Thank you for the update.
In the portable version the insert matrix dialog and the matrix() function seem to be dead. mat() however, works. |
As usual, an excellent job Originally Posted by: mkraska Thank you for the update.
In the portable version the insert matrix dialog and the matrix() function seem to be dead. mat() however, works. Can't confirm, both mono and portable versions work for me, on win7 x64... best regards, w3b5urf3r |
Joined: 19/04/2013(UTC) Posts: 46 Location: Podkarpackie, Poland Was thanked: 7 time(s) in 7 post(s)
Andrey, I congratulate the new program version. The perfect work! The problem is however. After the installation of the MapleWrapper_20130602 in the new program version, during the test of its execution is shown the communication: " The error appeared during the test of lading an external programme. The plugin will be disconnected.
Cannot load one or the greater number of required types. To obtain more information, receive properties LoaderExceptions." I made the test on several computers. Everywhere the same result. Regards, Janusz Edited by user 03 June 2013 16:15:45(UTC)
XY Plot, 3D Plot, Maple Wrapper and all others (with regions) must be recompiled for this build. |
Russia ☠forever Viacheslav N. Mezentsev |
Hello Uni,
Thank you for this information. Patiently I will wait for the new version of the MapleWrapper plugin.
Regards, Janusz
There seems to be a localization issue. If arg sep is set to ; then no functions with more than 1 arg can be used, matrix in a previous post was just one of them. If I use setting . for dec sep and , for arg sep then no problems, in both versions (portable, msi installer)
system: win7 x64 german locale
I was curious and played around with the extension manager. Providing access to some sort of online repository is a good idea. Would be fine, if local files could be included by a button "make current sheet snippet" or "make current sheet example" including upload option.
A by user directory structure is created in the settings directory for downloaded plugins and snippets.
You can download extensions from the web and store them locally. Applications (SMath viewer programs) are not stored there, instead you specify a storage location, which SMath immediately forgets about. Thus "Local storage" is empty, regardless of what you downloaded.
Snippets that are put to the local SMath install dir snippet subdir are sometimes recognized by the manager, sometimes not. The file fill.sm shows up under local storage, hatch.sm does not. The latter, however, is offered online and goes to the local settings dir. If I put my original file hatch.sm to that directory, it is still not recognized by the manager. the only difference that I can find between my local file and the one downloaded is the identity tag in the xml structure.
The small number in the upper left corner of the snippets description in the extension manager seems to reflect the revision tag in the xml structure. What does this number say?
Sorry for not providing the files as attachments, this seems not possible at the moment or in this topic or just by me, who knows... - fill.sm, recognized as snippet - hatch1.sm, local file, not recognized - hatch.sm, downloaded via extension manager
Adding examples using the old way (putting to the examples dir in the installation) works. |
Originally Posted by: mkraska If I put my original file hatch.sm to that directory, it is still not recognized by the manager. the only difference that I can find between my local file and the one downloaded is the identity tag in the xml structure. And you are right, the identity tag is critical, Andrey can clarify you how to update this file. Originally Posted by: mkraska The small number in the upper left corner of the snippets description in the extension manager seems to reflect the revision tag in the xml structure. What does this number say? Is the revision (a progressive number that show the number of saves)... BTW before uploading the file one can manually change this number from the code... Originally Posted by: mkraska Sorry for not providing the files as attachments, this seems not possible at the moment or in this topic or just by me, who knows... No files can be uploaded in this forum section best regards, w3b5urf3r Edited by user 04 June 2013 00:22:55(UTC)
Originally Posted by: smath - Extensions Manager implemented;
As a possible enhancement, would be useful an icon/button that open (or point to) a window that show the functions contained in the selected plugin. best regards, w3b5urf3r |
Originally Posted by: w3b5urf3r_reloaded Originally Posted by: smath - Extensions Manager implemented;
As a possible enhancement, would be useful an icon/button that open (or point to) a window that show the functions contained in the selected plugin. best regards, w3b5urf3r Agree, On the other hand, some additional functions category should be introduced. At the moment all the functions are inside "All" category. The external plugin functions are not distinguishable from the core SMath functions in the category list. Regards, Radovan |
Originally Posted by: mkraska There seems to be a localization issue. If arg sep is set to ; then no functions with more than 1 arg can be used, matrix in a previous post was just one of them. Thank you! Will fix it.
Originally Posted by: mkraska Would be fine, if local files could be included by a button "make current sheet snippet" or "make current sheet example" including upload option. Snippets and simple examples are different - examples without "shortcut" set cannot be used as snippets by design. Although a person who want to publish worksheet as an example AND as a snippet can do it without any restrictions (again, snippet should contain "shortcut" . Originally Posted by: mkraska A by user directory structure is created in the settings directory for downloaded plugins and snippets. Correct. Originally Posted by: mkraska Applications (SMath viewer programs) are not stored there, instead you specify a storage location, which SMath immediately forgets about. Thus "Local storage" is empty, regardless of what you downloaded. This is by design. User is able to select any convenient path for downloaded application and it can be then moved anywhere - so there is no common possibility to track such files by SMath Studio. Originally Posted by: mkraska Snippets that are put to the local SMath install dir snippet subdir are sometimes recognized by the manager, sometimes not. The file fill.sm shows up under local storage, hatch.sm does not. The latter, however, is offered online and goes to the local settings dir. If I put my original file hatch.sm to that directory, it is still not recognized by the manager. the only difference that I can find between my local file and the one downloaded is the identity tag in the xml structure. There is a requirement - any file should contain GUID and VERSION to be handled by Extensions Manager. SMath Studio adds that meta-data automatically starting from 0.96. If there are no version or guid specified I can't predict what behavior we will have. Originally Posted by: mkraska The small number in the upper left corner of the snippets description in the extension manager seems to reflect the revision tag in the xml structure. What does this number say? This number is actually a revision of the file - some kind of worksheet's version. As w3b5urf3r_reloaded mentioned, by default it is number of saves. Best regards, Andrey Ivashov.
on 04/06/2013(UTC), on 05/06/2013(UTC)
Hello, I have seen the absence of contextual menu: Optimization, Decimal Places, Fraction ... sergio
Originally Posted by: PompelmoTell Hello, I have seen the absence of contextual menu: Optimization, Decimal Places, Fraction ... sergio I have seen that once, but can not reproduced. How did you get it? Regards, Radovan |
on 05/06/2013(UTC), on 05/06/2013(UTC)
Originally Posted by: ioan92 Hi to the Greats Plugin Builders - Davide & Viacheslav,Thanks again for your precious work !!! Please take a look on your products; it seems that a lot are no more working with the last SMath Nightly build. All my respectful thanks,
Ioan We knows, there is an issue with third-party references. Don't worry Andrey know this issues and he will fix it best regards, Davide |
Originally Posted by: ioan92 Hi all,
I don't know if I am an isolated case or if this happens to others also:
matrix insert is no more responding.
Please check.
Ioan
Originally Posted by: smath Originally Posted by: mkraska There seems to be a localization issue. If arg sep is set to ; then no functions with more than 1 arg can be used, matrix in a previous post was just one of them. Thank you! Will fix it. I think this is the issue ( above in this thread) Edited by user 06 June 2013 00:45:57(UTC)
I cannot input the function diff(2) or diff(3) using the "Tab" key. There is the same result when I try to open the parenthesis instead of use the Tab key.
Regards, Janusz
