2 Pages12>
Offline Andrey Ivashov
#1 Posted : 03 June 2013 03:24:57(UTC)
Nightly build: SMath Studio 0.96.4902 available
Important notes
  • Remove all third-party plug-ins from "plugins" folder of previous installed SMath Studio before installing SMath Studio 0.96.4902;
  • Instructions regarding how to publish your Examples/Plugins/Applications/Snippets to make them available within Extensions Manager will be added a bit later.
Latest changes (against SMath Studio 0.96.4884)
  • Extensions Manager implemented;
  • Insert Matrix dialog improved to select input values on focus;
  • MSI installer improved to support different DPI settings;
  • Added full support for assemblies implements more then one plugin;
  • Execution script added to Mono Package;
  • Added ability to export files to supported formats using command prompt;
  • Fixed critical issue appears on context menu open for Region based on RegionHolder with hidden input data;
  • Dependencies handling improved for sm/smz files;
  • SMath Viewer repaired to correctly support plug-ins which contains several files;
  • Semicolon symbol prohibited to be used as a part of variable/function name;
  • Refactoring.
Download
Edited by user 03 June 2013 03:30:08(UTC)  | Reason: Not specified
on 03/06/2013(UTC),  on 03/06/2013(UTC),  on 03/06/2013(UTC),  on 05/06/2013(UTC)
Offline omorr
#2 Posted : 03 June 2013 07:59:48(UTC)
omorr
Serbia
Thank you Andrey Good
Just started Smath in Linux using Mono execution script. It seems that closing newly introduced Extension Manager will close SMath to.
Offline mkraska
#3 Posted : 03 June 2013 11:12:51(UTC)
mkraska
Was thanked: 1119 time(s) in 717 post(s)
Thank you for the update.
In the portable version the insert matrix dialog and the matrix() function seem to be dead. mat() however, works.
#4 Posted : 03 June 2013 11:32:29(UTC)
Was thanked: 1323 time(s) in 873 post(s)
Shok As usual, an excellent job Thank you
Can't confirm, both mono and portable versions work for me, on win7 x64...
best regards,
w3b5urf3r
Offline sija
#5 Posted : 03 June 2013 15:07:01(UTC)
sija
Poland
Andrey,
I congratulate the new program version. The perfect work!
The problem is however. After the installation of the MapleWrapper_20130602 in the new program version, during the test of its execution is shown the communication:
"The error appeared during the test of lading an external programme. The plugin will be disconnected.
Cannot load one or the greater number of required types. To obtain more information, receive properties LoaderExceptions.
I made the test on several computers. Everywhere the same result.
Janusz
Edited by user 03 June 2013 16:15:45(UTC)  | Reason: Not specified
Offline uni
#6 Posted : 03 June 2013 15:12:57(UTC)
uni
XY Plot, 3D Plot, Maple Wrapper and all others (with regions) must be recompiled for this build.
Russia ☭ forever
Viacheslav N. Mezentsev
Offline sija
#7 Posted : 03 June 2013 15:21:34(UTC)
sija
Poland
Hello Uni,
Thank you for this information. Patiently I will wait for the new version of the MapleWrapper plugin.
Janusz
Offline mkraska
#8 Posted : 03 June 2013 17:29:51(UTC)
mkraska
There seems to be a localization issue. If arg sep is set to ; then no functions with more than 1 arg can be used, matrix in a previous post was just one of them. If I use setting . for dec sep and , for arg sep then no problems, in both versions (portable, msi installer)
system: win7 x64 german locale
on 03/06/2013(UTC)
Offline mkraska
#9 Posted : 04 June 2013 00:03:54(UTC)
mkraska
I was curious and played around with the extension manager. Providing access to some sort of online repository is a good idea. Would be fine, if local files could be included by a button "make current sheet snippet" or "make current sheet example" including upload option.
A by user directory structure is created in the settings directory for downloaded plugins and snippets.
You can download extensions from the web and store them locally. Applications (SMath viewer programs) are not stored there, instead you specify a storage location, which SMath immediately forgets about. Thus "Local storage" is empty, regardless of what you downloaded.
Snippets that are put to the local SMath install dir snippet subdir are sometimes recognized by the manager, sometimes not.
The file fill.sm shows up under local storage, hatch.sm does not. The latter, however, is offered online and goes to the local settings dir. If I put my original file hatch.sm to that directory, it is still not recognized by the manager. the only difference that I can find between my local file and the one downloaded is the identity tag in the xml structure.
The small number in the upper left corner of the snippets description in the extension manager seems to reflect the revision tag in the xml structure. What does this number say?
Sorry for not providing the files as attachments, this seems not possible at the moment or in this topic or just by me, who knows...
- fill.sm, recognized as snippet
- hatch1.sm, local file, not recognized
- hatch.sm, downloaded via extension manager
Adding examples using the old way (putting to the examples dir in the installation) works.
#10 Posted : 04 June 2013 00:13:50(UTC)
And you are right, the identity tag is critical, Andrey can clarify you how to update this file.
Is the revision (a progressive number that show the number of saves)... BTW before uploading the file one can manually change this number from the code...
No files can be uploaded in this forum section Good
best regards,
w3b5urf3r
Edited by user 04 June 2013 00:22:55(UTC)  | Reason: Not specified
on 04/06/2013(UTC)
#11 Posted : 04 June 2013 10:52:13(UTC)
As a possible enhancement, would be useful an icon/button that open (or point to) a window that show the functions contained in the selected plugin.
best regards,
w3b5urf3r
Offline omorr
#12 Posted : 04 June 2013 11:35:32(UTC)
omorr
Serbia
best regards,
w3b5urf3r
Agree,
On the other hand, some additional functions category should be introduced. At the moment all the functions are inside "All" category. The external plugin functions are not distinguishable from the core SMath functions in the category list.
on 04/06/2013(UTC)
#13 Posted : 04 June 2013 22:31:10(UTC)
Thank you!
Will fix it.
on 04/06/2013(UTC)
#14 Posted : 04 June 2013 22:43:20(UTC)
Snippets and simple examples are different - examples without "shortcut" set cannot be used as snippets by design. Although a person who want to publish worksheet as an example AND as a snippet can do it without any restrictions (again, snippet should contain "shortcut"Wink.
Correct.
This is by design. User is able to select any convenient path for downloaded application and it can be then moved anywhere - so there is no common possibility to track such files by SMath Studio.
There is a requirement - any file should contain GUID and VERSION to be handled by Extensions Manager. SMath Studio adds that meta-data automatically starting from 0.96. If there are no version or guid specified I can't predict what behavior we will have.
This number is actually a revision of the file - some kind of worksheet's version. As w3b5urf3r_reloaded mentioned, by default it is number of saves.
Best regards, Andrey Ivashov.
on 04/06/2013(UTC),  on 05/06/2013(UTC)
Offline PompelmoTell
#15 Posted : 05 June 2013 12:57:53(UTC)
PompelmoTell
I have seen the absence of contextual menu: Optimization, Decimal Places, Fraction ... Sad
Offline omorr
#16 Posted : 05 June 2013 14:33:55(UTC)
omorr
Serbia
I have seen that once, but can not reproduced. How did you get it?
#17 Posted : 05 June 2013 18:40:18(UTC)
This is related to an issue mentioned in http://en.smath.info/for...d-region-is-deleted.aspx - fixed.
Regards.
on 05/06/2013(UTC),  on 05/06/2013(UTC)
#18 Posted : 05 June 2013 22:36:38(UTC)
Originally Posted by: ioan92 Go to Quoted Post
Hi to the Greats Plugin Builders - Davide & Viacheslav,
Thanks again for your precious work !!!Clapping
Please take a look on your products; it seems that a lot are no more working with the last SMath Nightly build.
All my respectful thanks,
Ioan
We knows, there is an issue with third-party references. Don't worry Andrey know this issues and he will fix it Wink
best regards,
Davide
on 05/06/2013(UTC)
#19 Posted : 05 June 2013 23:42:57(UTC)
Hi all,
I don't know if I am an isolated case or if this happens to others also:
matrix insert is no more responding.
Please check.
Ioan
Thank you!
Will fix it.
I think this is the issue (above in this thread) Huh
Edited by user 06 June 2013 00:45:57(UTC)  | Reason: Not specified
on 06/06/2013(UTC)
Offline sija
#20 Posted : 09 June 2013 19:25:56(UTC)
sija
Poland
I cannot input the function diff(2) or diff(3) using the "Tab" key. There is the same result when I try to open the parenthesis instead of use the Tab key.
Janusz
2 Pages12>
