Offline mateo
#1 Posted : 23 September 2022 13:54:39(UTC)
mateo
I can use Solve using the command Insert > Function. But if I write the same directly without the Menu, it won't work. What could be the reason?
Offline PompelmoTell
#2 Posted : 23 September 2022 14:20:34(UTC)
PompelmoTell
Was thanked: 107 time(s) in 91 post(s)
You should check the use of capital or tiny "s". Also only if you have installed the "Maxima" plugin you have both "solve" and "Solve" that have a different solutor and also a different form
Offline mateo
#3 Posted : 23 September 2022 15:28:54(UTC)
mateo
Thank you. I wrote solve indeed with tiny s and I don't have the Maxima plugin. However, I tried it once again today and it worked.
#4 Posted : 23 September 2022 19:38:41(UTC)
Was thanked: 941 time(s) in 769 post(s)
