Offline mateo
#1 Posted : 23 September 2022 13:54:39(UTC)
mateo
I can use Solve using the command Insert > Function. But if I write the same directly without the Menu, it won't work. What could be the reason?
Offline PompelmoTell
#2 Posted : 23 September 2022 14:20:34(UTC)
PompelmoTell
You should check the use of capital or tiny "s". Also only if you have installed the "Maxima" plugin you have both "solve" and "Solve" that have a different solutor and also a different form
Offline mateo
#3 Posted : 23 September 2022 15:28:54(UTC)
mateo
Thank you. I wrote solve indeed with tiny s and I don't have the Maxima plugin. However, I tried it once again today and it worked.
#4 Posted : 23 September 2022 19:38:41(UTC)
