SMath Studio Forum
Questions
Do I have to use Insert > Function in order to use solve
I can use Solve using the command Insert > Function. But if I write the same directly without the Menu, it won't work. What could be the reason?
Joined: 23/12/2011(UTC) Posts: 309   Location: italy Was thanked: 106 time(s) in 90 post(s)
You should check the use of capital or tiny "s". Also only if you have installed the "Maxima" plugin you have both "solve" and "Solve" that have a different solutor and also a different form
Thank you. I wrote solve indeed with tiny s and I don't have the Maxima plugin. However, I tried it once again today and it worked.
Joined: 04/07/2015(UTC) Posts: 6,323  Was thanked: 918 time(s) in 746 post(s)
SMath Studio Forum
Questions
