7 Pages«<4567>
Offline uni
#101 Posted : 20 September 2021 22:14:43(UTC)
uni
Was thanked: 1400 time(s) in 817 post(s)
Please try to update the plugin. Your version is from last year and is out of date.
Russia ☭ forever (git.io/vOZo0)
Viacheslav N. Mezentsev
Offline Ricardo Herrera
#102 Posted : 20 September 2021 22:48:37(UTC)
Ricardo Herrera
Peru
XLSXupdate.txt (2kb) downloaded 26 time(s).
Update plugin, but error persists.
Keep holding
Edited by user 20 September 2021 23:08:14(UTC)  | Reason: Not specified
Offline uni
#103 Posted : 21 September 2021 01:19:45(UTC)
uni
This problem appears due to the presence of old keys in the registry, which will contain the wrong path to Excel. Try to search in Google for a solution to your problem using the error text from the log file:
Code:
Excel HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED)
Offline joaobr
#104 Posted : 21 September 2021 17:29:09(UTC)
joaobr
Brazil
Was thanked: 7 time(s) in 6 post(s)
Ricardo, I updated the plugin and made a Quick Repair in my Office 365, restarted the pc and now it works perfectly.
The issue is some bug in Office register.
Thank you for your compliments, Ricardo! Glad to see my videos are helping!
#105 Posted : 21 September 2021 18:37:50(UTC)
Ricardo Herrera
Peru
Thank you very much I have reinstalled office and now it works.
thanks for everyone's help.
A hug from a distance.
to all.
thanks 1 user thanked Ricardo Herrera for this useful post.
on 21/09/2021(UTC)
Offline joaobr
#106 Posted : 01 November 2021 14:46:47(UTC)
joaobr
Brazil
Hi! I'm having trouble sending String variables to Excel.
For instance, ". - / ! ? ;" turns into \002E\\0020\\002D\\0020\\002F\\0020\\0021\\0020\\003F\\0020\\003B\ in Excel.
I'm using most recent SMath and Excel I/O versions.
Edited by user 01 November 2021 15:47:34(UTC)  | Reason: Not specified
#107 Posted : 01 November 2021 16:05:32(UTC)
Ricardo Herrera
Peru
Hello, good morning, could I send a screenshot to see the error that generates a hug from a distance
Offline MauroMen
#108 Posted : 10 November 2021 18:26:03(UTC)
MauroMen
Rank: Member
Colombia
Hi, I have the same problem as Ricardo, any recommendations to solve it?
Edited by moderator 03 July 2022 10:48:26(UTC)  | Reason: Not specified
Offline uni
#109 Posted : 11 November 2021 11:35:29(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- excel_in(): text encode issue fixed.
on 11/11/2021(UTC),  on 11/11/2021(UTC)
Offline MauroMen
#110 Posted : 11 November 2021 14:57:18(UTC)
MauroMen
Rank: Member
Colombia
Thank you very much, fixed with update Good
Offline uni
#111 Posted : 03 July 2022 10:18:14(UTC)
uni
Plugin updated.
Changes:
- added support for environment variables;
- refactored.
on 03/07/2022(UTC)
Offline Razonar
#112 Posted : 03 July 2022 11:04:57(UTC)
Razonar
Uruguay
Was thanked: 976 time(s) in 610 post(s)
Originally Posted by: uni Go to Quoted Post
Plugin updated. ...
Hi Viacheslav. An example about what does that mean? Thanks.
Offline uni
#113 Posted : 03 July 2022 12:10:06(UTC)
uni
You can use operating system environment variables in the file path.
thanks 4 users thanked uni for this useful post.
on 03/07/2022(UTC),  on 03/07/2022(UTC),  on 03/07/2022(UTC),  on 07/07/2022(UTC)
Offline MauroMen
#114 Posted : 07 July 2022 17:54:58(UTC)
MauroMen
Rank: Member
Colombia
Hello thanks for the plugin, I found a problem in the excel_In() command. I present it in the image, I hope it can be resolved in future versions.
Offline uni
#115 Posted : 08 July 2022 10:45:19(UTC)
uni
Plugin updated. Please try.
Changes:
- ToCell(): Globals.Excel.DecimalSeparator replaced by the CultureInfo.GetCultureInfo( "en-EN" ).NumberFormat.NumberDecimalSeparator;
- ToCell(): Double.Parse() fixed;
- part of the book "Excel 2002 VBA Programmer's Reference" added (Chapter 22. International Issues).
Click to enlarge
Edited by user 08 July 2022 10:49:41(UTC)  | Reason: Not specified
on 08/07/2022(UTC)
Offline uni
#116 Posted : 08 July 2022 13:01:35(UTC)
uni
It is possible to simplify the interface. I can add a new feature. You can suggest your own version for a new feature.
Edited by user 08 July 2022 13:22:10(UTC)  | Reason: Not specified
Offline uni
#117 Posted : 09 July 2022 12:43:56(UTC)
uni
In a future release I will remove functions from ExcelIOCom to XLSXupdate. One function and one operand will be added.
Edited by user 09 July 2022 16:26:10(UTC)  | Reason: Not specified
on 09/07/2022(UTC),  on 09/07/2022(UTC)
Offline uni
#118 Posted : 09 July 2022 18:41:31(UTC)
uni
SMath Studio compatibility Examples
Changes:
- excel operand and excel() function added;
- readCell() and writeCell() moved from the ExcelIOCom plugin;
- examples added;
- refactored.
on 11/07/2022(UTC)
Offline uni
#119 Posted : 12 July 2022 09:40:45(UTC)
uni
There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable:
excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML"
Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as:
- create books, add and delete sheets;
- accessing named ranges;
I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable.
on 16/07/2022(UTC)
Offline Alex M.
#120 Posted : 14 November 2022 21:29:27(UTC)
Alex M.
Was thanked: 127 time(s) in 96 post(s)
Hello Uni,
It has been years since I have touched this plugin. Thank you for keeping it up to date and expanding its functionality! I use this plugin close to daily. I intend to add couple function calls to work with EXCEL Macro and perhaps a region to display the EXCEL range (so that Image Region plugin is not needed).
What do I need to know so that I do not interfere with useful changes you have made?
Cheers
Sasha
7 Pages«<4567>
