SMath Studio Forum
Extensions
EXCEL (2003+) I/O with recalculation and export to PNG
Please try to update the plugin. Your version is from last year and is out of date. |
Joined: 04/08/2020(UTC) Posts: 8 Location: RicardoH Was thanked: 1 time(s) in 1 post(s)
XLSXupdate.txt (2kb) downloaded 22 time(s).Update plugin, but error persists. Keep holding Edited by user 20 September 2021 23:08:14(UTC)
| Reason: Not specified
This problem appears due to the presence of old keys in the registry, which will contain the wrong path to Excel. Try to search in Google for a solution to your problem using the error text from the log file: Code:Excel HRESULT: 0x8002801D (TYPE_E_LIBNOTREGISTERED)
Joined: 12/02/2018(UTC) Posts: 62 Location: Belém Was thanked: 7 time(s) in 6 post(s)
Ricardo, I updated the plugin and made a Quick Repair in my Office 365, restarted the pc and now it works perfectly. The issue is some bug in Office register.
Thank you for your compliments, Ricardo! Glad to see my videos are helping!
Thank you very much I have reinstalled office and now it works. thanks for everyone's help. A hug from a distance. to all.
1 user thanked Ricardo Herrera for this useful post.
Hi! I'm having trouble sending String variables to Excel. For instance, ". - / ! ? ;" turns into \002E\\0020\\002D\\0020\\002F\\0020\\0021\\0020\\003F\\0020\\003B\ in Excel. I'm using most recent SMath and Excel I/O versions. Edited by user 01 November 2021 15:47:34(UTC)
Hello, good morning, could I send a screenshot to see the error that generates a hug from a distance
Joined: 20/11/2016(UTC) Posts: 7 Location: Bogota Was thanked: 1 time(s) in 1 post(s)
Hi, I have the same problem as Ricardo, any recommendations to solve it?
Edited by moderator 03 July 2022 10:48:26(UTC)
Plugin updated. Changes: - excel_in(): text encode issue fixed. |
on 11/11/2021(UTC), on 11/11/2021(UTC)
Thank you very much, fixed with update
Plugin updated. Changes: - added support for environment variables; - refactored. |
Hi Viacheslav. An example about what does that mean? Thanks. Best regards. Alvaro.
You can use operating system environment variables in the file path. |
4 users thanked uni for this useful post.
on 03/07/2022(UTC), on 03/07/2022(UTC), on 03/07/2022(UTC), on 07/07/2022(UTC)
Hello thanks for the plugin, I found a problem in the excel_In() command. I present it in the image, I hope it can be resolved in future versions.
Originally Posted by: MauroMen I found a problem in the excel_In() command. I present it in the image, I hope it can be resolved in future versions. Plugin updated. Please try. Changes: - ToCell(): Globals.Excel.DecimalSeparator replaced by the CultureInfo.GetCultureInfo( "en-EN" ).NumberFormat.NumberDecimalSeparator; - ToCell(): Double.Parse() fixed; - part of the book "Excel 2002 VBA Programmer's Reference" added (Chapter 22. International Issues). Edited by user 08 July 2022 10:49:41(UTC)
It is possible to simplify the interface. I can add a new feature. You can suggest your own version for a new feature. Edited by user 08 July 2022 13:22:10(UTC)
In a future release I will remove functions from ExcelIOCom to XLSXupdate. One function and one operand will be added. Edited by user 09 July 2022 16:26:10(UTC)
on 09/07/2022(UTC), on 09/07/2022(UTC)
Plugin updated. Please try. Changes: - excel operand and excel() function added; - readCell() and writeCell() moved from the ExcelIOCom plugin; - examples added; - refactored. |
There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable: excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML" Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as: - create books, add and delete sheets; - accessing named ranges; - ... I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable. |
Originally Posted by: uni There are several ways to work with Excel documents. I can add support for ClosedXML and EPPlus. In this case I will rename the plugin to Excel Toolbox. The choice of how to work with Excel can be done using a variable: excel:="driver:COM" or excel:="driver:EPPlus" or excel:="driver:ClosedXML" Each of the drivers provides its own capabilities. It is possible to try to implement other features, such as: - create books, add and delete sheets; - accessing named ranges; - ... I could change the language used in the plugin (VB.NET), but decided to leave it as an example of development in this language. This introduces some problems, but they are solvable. Hello Uni, It has been years since I have touched this plugin. Thank you for keeping it up to date and expanding its functionality! I use this plugin close to daily. I intend to add couple function calls to work with EXCEL Macro and perhaps a region to display the EXCEL range (so that Image Region plugin is not needed). What do I need to know so that I do not interfere with useful changes you have made? Cheers Sasha
SMath Studio Forum
Extensions
