Offline uni
#1 Posted : 21 January 2019 03:29:14(UTC)
uni
Was thanked: 1169 time(s) in 675 post(s)
lsoda (Livermore Solver for Ordinary Differential Equations)
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
Functions list:
lsoda(ics, xmin, xmax, steps, ode) solves the initial value problem for stiff or nonstiff systems (uses Adams/BDF methods).
Arguments:
  • ics is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
  • xmin and xmax are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
  • steps is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
  • ode is a vector function of the form D(x,y) specifying the right-hand side of the system
Options:
- AbsTol - absolute tolerance parameter, default value 10⁻⁷.
- RelTol - relative tolerance parameter, default value 10⁻⁴.
Click to enlarge
Links:
1. Solving Stiff ODEs.
2. Serial Fortran Solvers for ODE Initial Value Problems.
lsoda.integrate.sm (11kb) downloaded 56 time(s).
lsoda.kinetic1.sm (8kb) downloaded 40 time(s).
lsoda.kinetic2.sm (11kb) downloaded 33 time(s).
lsoda.kinetic3.sm (11kb) downloaded 32 time(s).
lsoda.test1.sm (12kb) downloaded 34 time(s).
lsoda.test2.sm (12kb) downloaded 32 time(s).
lsoda.Arenstorf Orbit.sm (16kb) downloaded 48 time(s).
lsoda.Amplitude detector.sm (21kb) downloaded 35 time(s).
lsoda.integrate.pdf (88kb) downloaded 59 time(s).
lsoda.kinetic1.pdf (75kb) downloaded 43 time(s).
lsoda.kinetic2.pdf (88kb) downloaded 40 time(s).
lsoda.kinetic3.pdf (83kb) downloaded 41 time(s).
lsoda.test1.pdf (88kb) downloaded 54 time(s).
lsoda.test2.pdf (91kb) downloaded 37 time(s).
lsoda.Arenstorf Orbit.pdf (94kb) downloaded 51 time(s).
lsoda.Amplitude detector.pdf (149kb) downloaded 39 time(s).
See also:
Mathcad Toolbox
DotNumerics
SADEL
Matlab C++ Math Library
OSLO
GNU Scientific Library (GSL)
Edited by user 23 December 2021 20:25:02(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 4 users thanked uni for this useful post.
on 21/01/2019(UTC),  on 21/01/2019(UTC),  on 21/01/2019(UTC),  on 21/01/2019(UTC)
Offline efus
#2 Posted : 02 December 2020 14:22:55(UTC)
efus
Hello Viacheslav,
I attach here the two different file, lsodaMAP3 have the problem solved, lsodaMAP2 show the error.
SMath version 0.99.7610.506
lsoda version 0.1.7175.9902
lsoda MAP2.sm (49kb) downloaded 18 time(s). lsoda MAP3.sm (52kb) downloaded 13 time(s). crash.pdf (79kb) downloaded 14 time(s).
Playing a little bit in the lsodaMAP2 I was able to make it show the chart with the "problem".
Let me know if you need anything else!
All the best
Francesco
Edited by user 02 December 2020 18:46:19(UTC)  | Reason: Not specified
Veniamo da molto lontano e andiamo molto lontano! Palmiro Togliatti
Offline uni
#3 Posted : 02 December 2020 23:49:33(UTC)
uni
The problem is in the X-Y Plot plugin. It cannot display the input data because it is outside the normal bounds. Also in the document somehow the min and max values of the axis are the same, which also results in an error. It will take a time to fix this. I haven't tested the plugin on bad data much.
Russia ☭ forever
Offline uni
#4 Posted : 09 December 2021 21:00:37(UTC)
uni
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
Russia ☭ forever
on 10/12/2021(UTC)
Offline uni
#5 Posted : 23 December 2021 15:53:30(UTC)
uni
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin. As far as I understand, the algorithm used in this solver is the same as used in Odesolve: Adams/BDF. This can be seen from the comments in the source code. If I can port this code to c#, then we will have the same solver as in Mathcad. I want to include it as a default solver in Mathcad Toolbox plugin.
Russia ☭ forever
on 23/12/2021(UTC)
