Offline uni
#1 Posted : 21 January 2019 03:29:14(UTC)
uni
lsoda (Livermore Solver for Ordinary Differential Equations)
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
Functions list:
lsoda(ics, xmin, xmax, steps, ode) solves the initial value problem for stiff or nonstiff systems (uses Adams/BDF methods).
Arguments:
  • ics is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
  • xmin and xmax are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
  • steps is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
  • ode is a vector function of the form D(x,y) specifying the right-hand side of the system
Options:
- AbsTol - absolute tolerance parameter, default value 10⁻⁷.
- RelTol - relative tolerance parameter, default value 10⁻⁴.
Click to enlarge Click to enlarge
Links:
1. Solving Stiff ODEs.
2. Serial Fortran Solvers for ODE Initial Value Problems.
lsoda.integrate.sm (11kb) downloaded 64 time(s).
lsoda.kinetic1.sm (8kb) downloaded 45 time(s).
lsoda.kinetic2.sm (11kb) downloaded 37 time(s).
lsoda.kinetic3.sm (11kb) downloaded 38 time(s).
lsoda.test1.sm (12kb) downloaded 38 time(s).
lsoda.test2.sm (12kb) downloaded 34 time(s).
lsoda.Arenstorf Orbit.sm (16kb) downloaded 58 time(s).
lsoda.Amplitude detector.sm (21kb) downloaded 36 time(s).
lsoda.integrate.pdf (88kb) downloaded 69 time(s).
lsoda.kinetic1.pdf (75kb) downloaded 49 time(s).
lsoda.kinetic2.pdf (88kb) downloaded 43 time(s).
lsoda.kinetic3.pdf (83kb) downloaded 44 time(s).
lsoda.test1.pdf (88kb) downloaded 57 time(s).
lsoda.test2.pdf (91kb) downloaded 39 time(s).
lsoda.Arenstorf Orbit.pdf (94kb) downloaded 56 time(s).
lsoda.Amplitude detector.pdf (149kb) downloaded 41 time(s).
See also:
Mathcad Toolbox
DotNumerics
SADEL
Matlab C++ Math Library
OSLO
GNU Scientific Library (GSL)
Edited by user 19 April 2023 20:53:02(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
thanks 4 users thanked uni for this useful post.
on 21/01/2019(UTC),  on 21/01/2019(UTC),  on 21/01/2019(UTC),  on 21/01/2019(UTC)
Offline efus
#2 Posted : 02 December 2020 14:22:55(UTC)
efus
Hello Viacheslav,
I attach here the two different file, lsodaMAP3 have the problem solved, lsodaMAP2 show the error.
SMath version 0.99.7610.506
lsoda version 0.1.7175.9902
lsoda MAP2.sm (49kb) downloaded 20 time(s). lsoda MAP3.sm (52kb) downloaded 13 time(s). crash.pdf (79kb) downloaded 14 time(s).
Playing a little bit in the lsodaMAP2 I was able to make it show the chart with the "problem".
Let me know if you need anything else!
All the best
Francesco
Edited by user 02 December 2020 18:46:19(UTC)  | Reason: Not specified
Veniamo da molto lontano e andiamo molto lontano! Palmiro Togliatti
Offline uni
#3 Posted : 02 December 2020 23:49:33(UTC)
uni
The problem is in the X-Y Plot plugin. It cannot display the input data because it is outside the normal bounds. Also in the document somehow the min and max values of the axis are the same, which also results in an error. It will take a time to fix this. I haven't tested the plugin on bad data much.
Russia ☭ forever
Offline uni
#4 Posted : 09 December 2021 21:00:37(UTC)
uni
Plugin updated.
Changes:
- added support for ODE systems in mathematical form;
- refactored.
Russia ☭ forever
on 10/12/2021(UTC)
Offline uni
#5 Posted : 23 December 2021 15:53:30(UTC)
uni
Plugin updated.
Changes:
- solution restructured;
- converting the task for the ODE solver to the numerical form is now performed through the Mathcad Toolbox plugin (to avoid code duplication), so it must be installed;
- refactored.
Solvers that support mathematical notation now reuse code from the Mathcad Toolbox plugin. Now there is no need to recompile every such plugin. As far as I understand, the algorithm used in this solver is the same as used in Odesolve: Adams/BDF. This can be seen from the comments in the source code. If I can port this code to c#, then we will have the same solver as in Mathcad. I want to include it as a default solver in Mathcad Toolbox plugin.
Russia ☭ forever
on 23/12/2021(UTC)
