Offline uni
#1 Posted : 21 January 2019 03:29:14(UTC)
uni
Was thanked: 1008 time(s) in 585 post(s)
lsoda
SMath Studio compatibility SMath Viewer compatibility mono compatibility Platform Extension page Sources
Functions list: lsoda(5)
lsoda(init, x1, x2, intvls, D) solves the initial value problem for stiff or nonstiff systems.
Arguments:
- init is either a vector of n real initial values, where n is the number of unknowns (or a single scalar initial value, in the case of a single ODE).
- x1 and x2 are real, scalar endpoints of the interval over which the solution to the ODE(s) is evaluated. Initial values in init are the values of the ODE function(s) evaluated at x1.
- intvls is the integer number of discretization intervals used to interpolate the solution function. The number of solution points is the number of intervals + 1.
- D is a vector function of the form D(x,y) specifying the right-hand side of the system
Options:
- AbsTol - absolute tolerance parameter, default value 10⁻⁷.
- RelTol - relative tolerance parameter, default value 10⁻⁴.
Links:
1. Solving Stiff ODEs.
2. Serial Fortran Solvers for ODE Initial Value Problems.
lsoda.integrate.sm (11kb) downloaded 45 time(s).
lsoda.kinetic1.sm (8kb) downloaded 35 time(s).
lsoda.kinetic2.sm (11kb) downloaded 29 time(s).
lsoda.kinetic3.sm (11kb) downloaded 28 time(s).
lsoda.test1.sm (12kb) downloaded 30 time(s).
lsoda.test2.sm (12kb) downloaded 29 time(s).
lsoda.Arenstorf Orbit.sm (16kb) downloaded 33 time(s).
lsoda.Amplitude detector.sm (21kb) downloaded 28 time(s).
lsoda.integrate.pdf (88kb) downloaded 52 time(s).
lsoda.kinetic1.pdf (75kb) downloaded 40 time(s).
lsoda.kinetic2.pdf (88kb) downloaded 37 time(s).
lsoda.kinetic3.pdf (83kb) downloaded 36 time(s).
lsoda.test1.pdf (88kb) downloaded 49 time(s).
lsoda.test2.pdf (91kb) downloaded 33 time(s).
lsoda.Arenstorf Orbit.pdf (94kb) downloaded 41 time(s).
lsoda.Amplitude detector.pdf (149kb) downloaded 36 time(s).
Edited by user 04 December 2020 07:23:24(UTC)  | Reason: Not specified
Russia ☭ forever
Viacheslav N. Mezentsev
💰 Support me for plugins development: https://yoomoney.ru/to/410013245578758
thanks 4 users thanked uni for this useful post.
on 21/01/2019(UTC),  on 21/01/2019(UTC),  on 21/01/2019(UTC),  on 21/01/2019(UTC)
Offline efus
#2 Posted : 02 December 2020 14:22:55(UTC)
efus
Hello Viacheslav,
I attach here the two different file, lsodaMAP3 have the problem solved, lsodaMAP2 show the error.
SMath version 0.99.7610.506
lsoda version 0.1.7175.9902
lsoda MAP2.sm (49kb) downloaded 15 time(s). lsoda MAP3.sm (52kb) downloaded 11 time(s). crash.pdf (79kb) downloaded 14 time(s).
Playing a little bit in the lsodaMAP2 I was able to make it show the chart with the "problem".
Let me know if you need anything else!
All the best
Francesco
Edited by user 02 December 2020 18:46:19(UTC)  | Reason: Not specified
Veniamo da molto lontano e andiamo molto lontano! Palmiro Togliatti
Offline uni
#3 Posted : 02 December 2020 23:49:33(UTC)
uni
The problem is in the X-Y Plot plugin. It cannot display the input data because it is outside the normal bounds. Also in the document somehow the min and max values of the axis are the same, which also results in an error. It will take a time to fix this. I haven't tested the plugin on bad data much.
Russia ☭ forever
#4 Posted : 03 December 2020 17:11:31(UTC)
Was thanked: 852 time(s) in 682 post(s)
... sanity check ISODA wrt all the examples.
#5 Posted : 03 December 2020 18:03:02(UTC)
... test more ISODA [Originator Mathsoft Collaboratory]
Interested users must be courageous enough to code,
especially for those above my denigrated SS 6179.
Offline uni
#6 Posted : 04 December 2020 07:16:54(UTC)
uni
Plugin name is lsoda. Function name is lsoda. Library name is LSODA. It is a part of LSODE (Livermore Solver for Ordinary Differential Equations).
Not ISODA. Use correct names.
Russia ☭ forever
