SMath Studio Forum
Questions
Result is above max allowed positive number
Joined: 07/12/2018(UTC) Posts: 44 Was thanked: 1 time(s) in 1 post(s)
Hell SMath-users, I have an questions regarding the errors "Result is above max allowed positive number". What is the reason of this? Interestingly, I have performed an evaluation directly in the expression, and there shows with SMath the prospect of the sum. Best regards, Andrey P.S. the Smath -file is attached . Calculation of the corner antenna.sm (416kb) downloaded 40 time(s).Edited by user 25 October 2021 11:16:05(UTC)
| Reason: Not specified
Originally Posted by: andrbig77 I have an questions regarding the errors "Result is above max allowed positive number". What is the reason of this? In short/general can't calculate, like in your example. Sometimes it is true if above ^307 ... below ^-307
Originally Posted by: Jean Giraud In short/general can't calculate, like in your example. Sometimes it is true if above ^307 ... below ^-307 A common example calling augment(,,,) is by default Symbolic. Next demand is Numeric red above Max
θ is a vector, so you have to vectorize functions. Error code is probably wrong, happened before. Also φ is not defined. If you don't do a symbolic calculation it needs to be defined. Regards
SMath Studio Forum
Questions
