Offline andrbig77
#1 Posted : 25 October 2021 11:14:32(UTC)
andrbig77
Hell SMath-users,
I have an questions regarding the errors "Result is above max allowed positive number".
What is the reason of this?
Interestingly, I have performed an evaluation directly in the expression, and there shows with SMath the prospect of the sum.
Best regards,
Andrey
P.S. the Smath -file is attached . Calculation of the corner antenna.sm (416kb) downloaded 35 time(s).
Edited by user 25 October 2021 11:16:05(UTC)  | Reason: Not specified
#2 Posted : 25 October 2021 14:29:26(UTC)
#3 Posted : 26 October 2021 14:03:27(UTC)
In short/general can't calculate, like in your example.
Sometimes it is true if above ^307 ... below ^-307
#4 Posted : 26 October 2021 18:37:25(UTC)
A common example calling augment(,,,) is by default Symbolic.
Next demand is Numeric red above Max
Offline overlord
#5 Posted : 26 October 2021 19:54:45(UTC)
Turkey
θ is a vector, so you have to vectorize functions. Error code is probably wrong, happened before.
Also φ is not defined. If you don't do a symbolic calculation it needs to be defined.
Similar Topics
Error: Result is above max allowed positive number (Bugs & Problems)
by datsnl 15/05/2013 08:30:46(UTC)
