Hello guys, please your help! I've trying for weeks to do the equivalent WHILE in Smath Studio... a big tool for me. But I really cant figure it out, after watching thousands of videos and web pages. This might be a dumb question, but I'm kinda desperate. I keep getting Z is not defined. See the following captures: Mathcad Smath Studio Thank you very much in advance. Regards Edited by user 07 September 2021 23:10:24(UTC)
| Reason: Bad Capture
Originally Posted by: metrvg Hello guys, please your help! I've trying for weeks to do the equivalent WHILE in Smath Studio... a big tool for me. But I really cant figure it out, after watching thousands of videos and web pages. This might be a dumb question, but I'm kinda desperate.
Regards SMath vectors/matrices don't start with 0 index. First matrix/vector element gets the index 1. Redesigning your code should make it tick. Either make your indexes +1 or change your range to start with 1. Regards
The mountains of Mathcad that I converted for Smath were done simply. 1. From the Mathcad default index 0, save the result. 2. set Mathcad ORIGIN 1 3. Run the program, doctor as indicated by the red message. I still have a gorgeous Mathcad ORIGIN 0 that couldn't be converted/doctored ORIGIN 1 ... Damned mystic to me ! Cheers ... Jean.
Does it make sense to sanity Smath vs Mathcad more generally ? Page9 Sanity Mathcad.sm (9kb) downloaded 23 time(s).
Originally Posted by: Jean Giraud Does it make sense to sanity Smath vs Mathcad more generally ? Page9 Sanity Mathcad.sm (9kb) downloaded 23 time(s). when I download the attachment, run it, the error happens : "j is not defined" Is it my PC's problem?
Originally Posted by: wty3000 when I download the attachment, run it, the error happens : "j is not defined" Is it my PC's problem? PC problem ? Maybe as no visitor reported problem. If so, can't explain ...
Originally Posted by: wty3000 when I download the attachment, run it, the error happens : "j is not defined" Is it my PC's problem? Could you please uninstall SMath and delete your smath config directory. Directory should be in "C:\Users\<username>\AppData\Roaming\SMath\". Delete the SMath directory in Roaming completely, purge it. And could you please download new version again and install it?
Originally Posted by: wty3000 when I download the attachment, run it, the error happens : "j is not defined" You can probably doctor wrt your SS version. Cheers ... Jean.
Guys, thanks for your advices, i've been progressing with Smath... BUT, I reached a new issue... and I still don't get it... i even did the calls step by step marked in red. What can be wrong in the sintax?? Check this out: Mathcad Smath Thank you very much in advance! Regards
Originally Posted by: metrvg What can be wrong in the syntax??
We can't really tell what is the matter without the file. I guess you tried to see the result in same region with the algorithm. Same region result evaluation won't work with multi-line calculations. But it will give you the correct results in a separate evaluation. The syntax seems to appear correct. There is no problem with syntax. When I wrote everything as you did, it just works. Here is your algorithm written from scratch. Regards syntax.sm (6kb) downloaded 12 time(s).Edited by user 15 September 2021 01:35:26(UTC)
| Reason: Not specified
