Offline metrvg
#1 Posted : 07 September 2021 23:07:55(UTC)
metrvg
Hello guys, please your help! I've trying for weeks to do the equivalent WHILE in Smath Studio... a big tool for me. But I really cant figure it out, after watching thousands of videos and web pages. This might be a dumb question, but I'm kinda desperate.
I keep getting Z is not defined.
See the following captures:
Mathcad
Smath Studio
Thank you very much in advance.
Edited by user 07 September 2021 23:10:24(UTC)  | Reason: Bad Capture
Offline overlord
#2 Posted : 07 September 2021 23:36:04(UTC)
Turkey
SMath vectors/matrices don't start with 0 index.
First matrix/vector element gets the index 1.
Redesigning your code should make it tick.
Either make your indexes +1 or change your range to start with 1.
on 14/09/2021(UTC)
#3 Posted : 08 September 2021 17:33:22(UTC)
The mountains of Mathcad that I converted for Smath were done simply.
1. From the Mathcad default index 0, save the result.
2. set Mathcad ORIGIN 1
3. Run the program, doctor as indicated by the red message.
I still have a gorgeous Mathcad ORIGIN 0 that couldn't be
converted/doctored ORIGIN 1 ... Damned mystic to me !
#4 Posted : 08 September 2021 22:35:53(UTC)
Does it make sense to sanity Smath vs Mathcad more generally ?
Page9 Sanity Mathcad.sm (9kb) downloaded 23 time(s).
Offline wty3000
#5 Posted : 10 September 2021 08:12:09(UTC)
wty3000
China
when I download the attachment, run it,
the error happens : "j is not defined"
Is it my PC's problem?
#6 Posted : 11 September 2021 01:12:50(UTC)
PC problem ? Maybe as no visitor reported problem.
Offline overlord
#7 Posted : 11 September 2021 16:44:48(UTC)
Turkey
Could you please uninstall SMath and delete your smath config directory.
Directory should be in "C:\Users\<username>\AppData\Roaming\SMath\".
Delete the SMath directory in Roaming completely, purge it.
And could you please download new version again and install it?
#8 Posted : 12 September 2021 17:35:40(UTC)
You can probably doctor wrt your SS version.
Offline metrvg
#9 Posted : 14 September 2021 23:05:39(UTC)
metrvg
Guys, thanks for your advices, i've been progressing with Smath... BUT, I reached a new issue... and I still don't get it...
i even did the calls step by step marked in red.
What can be wrong in the sintax??
Check this out:
Mathcad
Smath
Thank you very much in advance!
Offline overlord
#10 Posted : 14 September 2021 23:25:05(UTC)
Turkey
What can be wrong in the syntax??
We can't really tell what is the matter without the file.
I guess you tried to see the result in same region with the algorithm.
Same region result evaluation won't work with multi-line calculations.
But it will give you the correct results in a separate evaluation.
The syntax seems to appear correct. There is no problem with syntax.
When I wrote everything as you did, it just works.
Here is your algorithm written from scratch.
syntax.sm (6kb) downloaded 12 time(s).
Edited by user 15 September 2021 01:35:26(UTC)  | Reason: Not specified
on 15/09/2021(UTC)
Guest (2)
