4 Pages<1234>
#41 Posted : 17 January 2018 10:48:45(UTC)
Originally Posted by: dacts Go to Quoted Post
is it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version"Wink" I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension?
The plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones); according to this issue, it should be possible if you compile the coolprop library (the core) in your machine and then you replace the one shared within this plugin.
Offline uni
#42 Posted : 18 June 2020 20:56:52(UTC)
uni
Updated.
Changes: refactored.
Russia ☭ forever
Viacheslav N. Mezentsev
on 19/06/2020(UTC)
Offline ElSid
#43 Posted : 11 February 2021 10:05:01(UTC)
ElSid
Originally Posted by: uni Go to Quoted Post
Updated.
I just started playing with this tool, so please be patient with my ignorance.
Updated to what? The version on my system is 6.1.0; however, the CoolProp website is on 6.4.1
I've also noticed that some of the description paramater names fail.
In addition, off of other threads, there appears to be "commands" that are no longer valid. An example would be FProp here.. Please advise.
I'm still searching for information as to what the other functions do (e.g. CoolProp_get_param_index)
Offline uni
#44 Posted : 11 February 2021 14:29:51(UTC)
uni
The plugin consists of two parts: a wrapper and a library. I didn't change the library, I just updated the wrapper source code.
It is possible to update the library version. I don't know where the documentation is and how the set of parameters changes depending on the version.
Edited by user 11 February 2021 14:31:22(UTC)  | Reason: Not specified
Russia ☭ forever
Offline ElSid
#45 Posted : 11 February 2021 16:24:03(UTC)
ElSid
What is the correct location for the wrapper? From the 1st post, these are invalid
Quote:
Official SMath wrapper (you have to build it by yourself, instructions in his documentation)
I may take a crack at compiling the newer version
Offline uni
#46 Posted : 11 February 2021 17:08:59(UTC)
uni
I can update the whole plugin including the library if you need.
Russia ☭ forever
Offline ElSid
#47 Posted : 11 February 2021 19:40:37(UTC)
ElSid
That would be appreciated. Version 6.1.0 is from 2016 and 6.4.1 is Aug. 2020.
On another post (by you), there seemed to be a relation with MathCad. In Sourceforge, MathCad and Prime are compiled by the CoolProp group. Could those files be used so we can just update the few dll files?
https://sourceforge.net/...op/files/CoolProp/6.4.1/
https://sourceforge.net/.../files/CoolProp/nightly/
Edited by user 11 February 2021 21:37:40(UTC)  | Reason: Added SMath Blog mentioning MathCAD for CoolProp
Offline uni
#48 Posted : 12 February 2021 07:14:30(UTC)
uni
Yes, you can use these libraries, but this is not a good idea. Better to use direct way.
Russia ☭ forever
Offline uni
#49 Posted : 12 February 2021 08:12:20(UTC)
uni
Sources
Updated. Please try.
Changes:
- CoolProp library updated to 6.4.1;
- refactored.
Code:
%appdata%\SMath\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f
Edited by user 12 February 2021 09:05:15(UTC)  | Reason: Not specified
Russia ☭ forever
on 13/02/2021(UTC)
Offline bbate
#50 Posted : 19 June 2021 02:11:35(UTC)
bbate
I am now getting the following error when using the CoolProp incompressible fluids library call
Initialize failed for backend: "?", fluid: "INCOMP::MEG-50%" fractions "[1.0000000 ]"; error: key [INCOMP::MEG-50%] was not found in string_to_index_map in JSONFluidLibrary : PropsSI("D","T",288.15,"P",101325.3532,"INCOMP::MEG-50%" )
This call was working March of this year. Any suggestions on what may be causing this issue?
Using:
CoolProp Wrapper Plugin 6.1.7713.14622
Smath Version: Smath Studio Desktop 64-bit, 0.99 (build: 7822)
CoolProp Version: CoolProp_v6.4.1.0
Edited by user 19 June 2021 02:13:50(UTC)  | Reason: Not specified
Offline uni
#51 Posted : 25 June 2021 12:53:31(UTC)
uni
PropsSI() function is from another plugin (mcadefi + mathcad coolprop lib).
Edited by user 25 June 2021 15:48:05(UTC)  | Reason: Not specified
Russia ☭ forever
on 25/06/2021(UTC)
Offline bbate
#52 Posted : 28 August 2021 01:22:19(UTC)
bbate
App Version: "0.99.7822.147"
Windows 10 Pro 64-bit
Issue: CoolProp Plugin functions not recognized by Smath
What I've tried:
- Adding/removing CoolProp Plugin (through the Extensions Manager in Smath Studio Desktop)
- re-installed SMATH Studio; deleting plugin folder after uninstall
- Re-installing CoolProp
Could you please provide guidance on what may be causing this issue?
thanks 1 user thanked bbate for this useful post.
on 28/08/2021(UTC)
Offline uni
#53 Posted : 28 August 2021 08:01:45(UTC)
uni
The reason for this behavior has not yet been clarified. Use this library for now, replacing the original one (\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\x.x.x.x\).
CoolPropWrapper-6.4.7910.17946.zip (2,606kb) downloaded 15 time(s).
Edited by user 28 August 2021 08:06:12(UTC)  | Reason: Not specified
Russia ☭ forever
Offline bbate
#54 Posted : 02 September 2021 23:11:40(UTC)
bbate
I've downloaded the .dll you provided and placed it in the plugins folder.
I get the following error message when I open Smath:
[img=https://ibb.co/mXxrqD6]PluginError[/img]
Edited by user 02 September 2021 23:13:53(UTC)  | Reason: Not specified
Offline uni
#55 Posted : 03 September 2021 10:14:56(UTC)
uni
You need to place it here:
Code:
%appdata%\SMath\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\6.4.7910.14793\
The last numbers may vary. This is the plugin folder. After replacing the file (CoolPropWrapper.dll), everything should work.
Russia ☭ forever
Offline uni
#56 Posted : 03 September 2021 12:56:54(UTC)
uni
SMath Studio compatibility
Plugin updated.
Changes:
- all function's classes now marked as public.
It should work now. You can update the plugin.
Russia ☭ forever
on 03/09/2021(UTC)
Offline Razonar
#57 Posted : 03 September 2021 18:55:30(UTC)
Razonar
Uruguay
Plugin updated.
Changes:
Hi Viacheslav, thanks, it works. But there are an small issue with the unicode strings
on 03/09/2021(UTC)
Offline uni
#58 Posted : 03 September 2021 21:32:39(UTC)
uni
Okay, you caught me.
Plugin updated. Try now.
Edited by user 03 September 2021 21:35:08(UTC)  | Reason: Not specified
Russia ☭ forever
on 04/09/2021(UTC)
Offline Razonar
#59 Posted : 04 September 2021 00:21:53(UTC)
Razonar
Uruguay
Hi. Great! Now the demo file in the first post works perfect.
Offline ioncube
#60 Posted : 19 April 2023 18:38:31(UTC)
ioncube
Pakistan
How can I get properties of mixtures e.g
Code:
CoolProp_Props("Dmass","T",273+100,"P",101.3*10^3,"Helium[0.5]&Xenon[0.5]")
ref: http://www.coolprop.org/...properties/Mixtures.html
Guest (4)
4 Pages<1234>
