Rank: Advanced Member Groups: Registered, Advanced Member Joined: 13/01/2012(UTC) Posts: 2,725 Location: Italy Was thanked: 1393 time(s) in 909 post(s)
Originally Posted by: dacts is it possible to run it on ubuntu 17.10 using mono?, I can't get it to work, when I try to evaluate "CoolProp_get_global_param_string("version" " I just get a little yellow message under the command that reads "CoolProp_x64", or do I need to compile the coolprop binaries ins some specific folder or is it a standalone plugin-extension? The plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones); according to this issue, it should be possible if you compile the coolprop library (the core) in your machine and then you replace the one shared within this plugin. |
Rank: Advanced Member Groups: Registered, Advanced Member Joined: 10/11/2010(UTC) Posts: 1,639 Was thanked: 1400 time(s) in 817 post(s)
Updated.
Changes: refactored. |
Russia ☭ forever (git.io/vOZo0) Viacheslav N. Mezentsev |
Originally Posted by: uni Updated. Changes: refactored. I just started playing with this tool, so please be patient with my ignorance. Updated to what? The version on my system is 6.1.0; however, the CoolProp website is on 6.4.1 I've also noticed that some of the description paramater names fail. In addition, off of other threads, there appears to be "commands" that are no longer valid. An example would be FProp here.. Please advise. I'm still searching for information as to what the other functions do (e.g. CoolProp_get_param_index)
Originally Posted by: Davide Carpi The plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones) The plugin consists of two parts: a wrapper and a library. I didn't change the library, I just updated the wrapper source code. It is possible to update the library version. I don't know where the documentation is and how the set of parameters changes depending on the version. Edited by user 11 February 2021 14:31:22(UTC)
Originally Posted by: uni Originally Posted by: Davide Carpi The plug-in it's composed by 3 files, the SMath wrapper plus 2 coolprop libraries (one for x86 systems, the other for x64 ones) The plugin consists of two parts: a wrapper and a library. I didn't change the library, I just updated the wrapper source code. It is possible to update the library version. I don't know where the documentation is and how the set of parameters changes depending on the version. What is the correct location for the wrapper? From the 1st post, these are invalid Quote:Official SMath wrapper (you have to build it by yourself, instructions in his documentation) I may take a crack at compiling the newer version
I can update the whole plugin including the library if you need. |
Originally Posted by: ElSid On another post (by you), there seemed to be a relation with MathCad. In Sourceforge, MathCad and Prime are compiled by the CoolProp group. Could those files be used so we can just update the few dll files? Yes, you can use these libraries, but this is not a good idea. Better to use direct way. |
Updated. Please try. Changes: - CoolProp library updated to 6.4.1; - refactored. Originally Posted by: ElSid What is the correct location for the wrapper? From the 1st post, these are invalid Code:%appdata%\SMath\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f
Edited by user 12 February 2021 09:05:15(UTC)
Joined: 21/11/2018(UTC) Posts: 4 Location: Langley, BC Was thanked: 1 time(s) in 1 post(s)
I am now getting the following error when using the CoolProp incompressible fluids library call Initialize failed for backend: "?", fluid: "INCOMP::MEG-50%" fractions "[1.0000000 ]"; error: key [INCOMP::MEG-50%] was not found in string_to_index_map in JSONFluidLibrary : PropsSI("D","T",288.15,"P",101325.3532,"INCOMP::MEG-50%" ) This call was working March of this year. Any suggestions on what may be causing this issue? Using: CoolProp Wrapper Plugin 6.1.7713.14622 Smath Version: Smath Studio Desktop 64-bit, 0.99 (build: 7822) CoolProp Version: CoolProp_v6.4.1.0 Edited by user 19 June 2021 02:13:50(UTC)
App Version: "0.99.7822.147" Windows 10 Pro 64-bit
Issue: CoolProp Plugin functions not recognized by Smath
What I've tried: - Adding/removing CoolProp Plugin (through the Extensions Manager in Smath Studio Desktop) - re-installed SMATH Studio; deleting plugin folder after uninstall - Re-installing CoolProp
Could you please provide guidance on what may be causing this issue?
1 user thanked bbate for this useful post.
The reason for this behavior has not yet been clarified. Use this library for now, replacing the original one (\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\x.x.x.x\). CoolPropWrapper-6.4.7910.17946.zip (2,606kb) downloaded 19 time(s).Edited by user 28 August 2021 08:06:12(UTC)
Originally Posted by: uni The reason for this behavior has not yet been clarified. Use this library for now, replacing the original one (\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\x.x.x.x\). CoolPropWrapper-6.4.7910.17946.zip (2,606kb) downloaded 19 time(s). I've downloaded the .dll you provided and placed it in the plugins folder. I get the following error message when I open Smath: [img=https://ibb.co/mXxrqD6]PluginError[/img] Edited by user 02 September 2021 23:13:53(UTC)
You need to place it here: Code:%appdata%\SMath\extensions\plugins\ca92ef03-c7da-4888-98ad-528482733e2f\6.4.7910.14793\
The last numbers may vary. This is the plugin folder. After replacing the file (CoolPropWrapper.dll), everything should work. |
Plugin updated. Changes: - all function's classes now marked as public. It should work now. You can update the plugin. |
Joined: 28/08/2014(UTC) Posts: 1,508 Was thanked: 974 time(s) in 609 post(s)
Originally Posted by: uni Plugin updated. Changes: - all function's classes now marked as public. It should work now. You can update the plugin. Hi Viacheslav, thanks, it works. But there are an small issue with the unicode strings Best regards. Alvaro.
Okay, you caught me. Plugin updated. Try now. Edited by user 03 September 2021 21:35:08(UTC)
Hi. Great! Now the demo file in the first post works perfect.
Joined: 04/12/2017(UTC) Posts: 70 Was thanked: 3 time(s) in 3 post(s)
