SMath Studio Forum
Samples
Double Integration using ode solvers
Joined: 28/08/2014(UTC) Posts: 973  Was thanked: 530 time(s) in 345 post(s)
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions. DoubleIntegralRK.sm (43kb) downloaded 64 time(s). DoubleIntegralRK.pdf (220kb) downloaded 73 time(s).Best regards. Alvaro.
on 04/06/2020(UTC), on 04/06/2020(UTC)
Joined: 02/05/2020(UTC) Posts: 41  Was thanked: 3 time(s) in 3 post(s)
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition? |
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman) |
Joined: 04/07/2015(UTC) Posts: 6,082  Was thanked: 890 time(s) in 718 post(s)
Originally Posted by: SteelCat  Can the change of variable be put in the procedure definition,? Like this: yes, just opposite plot. Double Switch [x, L].sm (7kb) downloaded 30 time(s).
on 18/06/2020(UTC), on 18/06/2020(UTC)
Originally Posted by: Jean Giraud  Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath. In the attached Laguerre and Legendre coeffs for the Gauss method. DoubleIntegralJean.sm (26kb) downloaded 36 time(s). DoubleIntegralJean.pdf (46kb) downloaded 35 time(s).Best regards. Alvaro
on 19/06/2020(UTC), on 19/06/2020(UTC)
Originally Posted by: Razonar  Hi Jean. Yes, can copy and paste. Thanks, Amigo !
SMath Studio Forum
Samples
