Offline Razonar
#1 Posted : 04 June 2020 07:40:08(UTC)
Razonar
Uruguay
Hi. This worksheet shows how to use an ode solver for evaluating a double integral over the region between two functions.
DoubleIntegralRK.sm (43kb) downloaded 73 time(s).
DoubleIntegralRK.pdf (220kb) downloaded 83 time(s).
on 04/06/2020(UTC),  on 04/06/2020(UTC)
Offline SteelCat
#2 Posted : 07 June 2020 19:21:46(UTC)
SteelCat
Thanks Alvaro for your example.
Can the change of variable be put in the procedure definition?
Physics is like sex. Sure, it may give some practical results, but that’s not why we do it. (R. Feynman)
#3 Posted : 08 June 2020 01:50:25(UTC)
Originally Posted by: SteelCat Go to Quoted Post
Can the change of variable be put in the procedure definition,?
Like this: yes, just opposite plot.
Double Switch [x, L].sm (7kb) downloaded 32 time(s).
Offline Razonar
#4 Posted : 18 June 2020 02:21:22(UTC)
Razonar
Uruguay
Hi. This is the double integral using Gauss Legendre quadrature.
GaussLegendreQuadrature.sm (61kb) downloaded 38 time(s).
GaussLegendreQuadrature.pdf (161kb) downloaded 34 time(s).
Yes.
DoubleIntegralSteelCat.sm (48kb) downloaded 41 time(s).
DoubleIntegralSteelCat.pdf (106kb) downloaded 28 time(s).
on 18/06/2020(UTC),  on 18/06/2020(UTC)
#5 Posted : 18 June 2020 17:26:19(UTC)
Keisan has longer Legendre than 64, but couldn't copy/paste ?
From other source: 63, 64.
Integrate Legendre [ Wr 24 ].sm (29kb) downloaded 36 time(s).
Offline Razonar
#6 Posted : 19 June 2020 03:35:42(UTC)
Razonar
Uruguay
Hi Jean. Yes, can copy and paste. Do that first into excel, and from there to the small SMathMatrixEditor and finally paste in SMath.
In the attached Laguerre and Legendre coeffs for the Gauss method.
DoubleIntegralJean.sm (26kb) downloaded 41 time(s).
DoubleIntegralJean.pdf (46kb) downloaded 38 time(s).
on 19/06/2020(UTC),  on 19/06/2020(UTC)
#7 Posted : 20 June 2020 13:39:28(UTC)
Thanks, Amigo !
